E36 328i (factory 2.8 so bigger brakes and stronger diff and shafts etc) Handling/performance: Coilovers with recently replaced rear shock and MeisterR rear springs E46 lower arms Modified hubs - drives nice and decent lock as usual with E36's Adjustable rear camber arms (pretty much brand new) Hydraulic handbrake with cylinder mounted remotely Welded 2.8 diff with 2.8 shafts (the original stuff) Interior: Full cage with double door bars Sparco bucket seat in good condition on Driftworks mounts Luke 4" harness in purple Genuine flat Momo steering wheel on boss Exterior: A bit tatty - odd panels etc as you can see Hartge wheels Zestino front tyres Car is very well specced and there's probably bits I've missed. Bad bits : Has an electrical fault where it intermittently runs badly , suspected ecu or crank sensor. Shell is tatty as you'd expect with a used drift car NO MOT and hasn't had one in my ownership as only bought for track . £1500 firm. (Decent considering the price of E36 these days) If I had the time and the patience i'd be fixing the running issue but I have a 1JZ project along with 2 other cars, this one was only ever bought for a bit of seat time! Cage etc will not be sold separately. Car is located in Chatham, Kent. Any questions, drop me a message on here or text 0750six331zero83 {} {} {} {}
Hi mate. I looking to start a little project and just wanted to know if there is disguised engine problems or what you may think it’ll be? Cheers
