Hi guys, I was just wondering if you were able to confirm if Monopros intended for use on a JZX100 would fit a JZX110? I have done some looking in to this, from what can see the general consensus is that they won't fit directly but it's possible to make them work with the correct top mounts? I have had a look on your shop and going by the pictures, the 90/100 struts and springs look a lot 'fatter' than the 110 items. I couldn't really see the top mounts to make a comparison but the bottom bushes looked a lot wider on the 110 items also. Is this something you guys would be able to advise on if possible please? Thank you!
Hi, they don't, but I'm not sure exactly what the difference is. JZX90 and 100 are the same. JZX110, JZS161 and SXE10 share similarities. I'm pretty sure it was an SXE10 HSD MonoPro kit that I fitted to my JZX110, just with stiffer spring rates.
