For Sale RB parts and Skyline bits for sale
Thread in 'Parts for sale' started by rockers, Feb 4, 2018.
  1. rockers
    rockers Member
    Got some new and used parts for sale,
    R32 Rb20 cooling fan shroud, no breaks i can see good nick - £30
    s4o2ko.
    R32 stock fitting Koyo radiator no leaks no temp sensor, - £90
    1zdt0lj.
    Rb20det set of 6 stock rods ringlands went so on rebuild i brought forged rods now no need for these - £80
    i38kko.
    Rb20/Rb25 exhaust manifold, stock mount turbo. going to go top mount, Guy i brought from said he paid alot but i think its a cheap ebay one tho looks alright - £80
    5vanig.
    R33 exhaust downpipe 3" - £30
    2m5fs04.
    Rb20 cooling fan with coupling no broken fins - £65
    2i0501x.
    R32 Air con fan - i have bit inclu aircon radiator ask if you need any random bits - fan - £30
    24chc8x.
    Cooling fan, i have two of these plus aluminium shroud that fit r32 rad will get more photos - £45 for fans and shroud unused
    ofbmm0.
    Rb20/25/26 crank collar to give you a longer drive for the oil pump on crank - this is from superforma i never used as went a different route, requires machining to crank - 45
    xn90kl.
    Rb25det neo oil pump (no gears) i got this to check some tolerances to a n1 housing i brought - £35
    comes with lid - no screws
    5k0krt.
    Rb N1 oil pump gears ( brandnew ) brought n1 pump then went with different gears - £90
    2wr3od3.
    will do deals on multiply parts -
    give me an offer if I am way off with the price on anything
    more to list when i take more photos
    Thanks
  2. mx51597
    mx51597 New Member
    Hi do you still have the fan where are you located bud?
  3. mx51597
    mx51597 New Member
    Also after the fan cover
  4. JackGardner
    JackGardner New Member
    Hi Pal do you still have the downpipe, will it fit r33 gtst and where are you locatwd? Thanks
  5. mickj15
    mickj15 Member
    be interested in manifold would you post
  6. dunnedriftin
    dunnedriftin Member
    Hi,
    Do you still have the fan shroud ?
  7. DarkDrifter
    DarkDrifter Member
    Exhaust Manifold still available ?
