Just a little parts clear out.. So I'll be brief with what I have . . 2jz full engine. Front sump configuration. Came out of a v300 aristo. 95k km on it. Good compression results Comes with full loom, ancillaries including injectors, turbos water pump, mounts etc Can be delivered. SOLDSOLD SOLD**********£2950********* SOLD SOLD SOLD ___________________ 1JZ vvti engine.. With loom and all ancillaries INCLUDING ECU to run it. Runs good. Serviced up to date. It has the kilometers on the service sticker in the picture. Can be put on a pallet and delivered **********£1650********* _______________ 1JZ NON VVTI engine. REAR sump configuration With injectors and ancillaries Including turbos (with loom and ecu) it was a manual. Ran good. Went hard ! Always serviced. This was from my soarer drift car. No problems. Oil has been drained. *********£1600********* ______________ Nissan skyline R34 GTT, HKS coilovers. Very Good Condition (see pic) Looking for around SOLD _______________ Nissan 200sx s14 Tein coilovers. Used condition. But not leaking SOLD ________________ Toyota aristo TEIN control master flex coilovers. Fully adjustable. Came off the same car as the Tom's 1jz. SOLD ______________ Evo 6 BREMBO brake calipers Good condition with dust covers all intact With brake hoses attached. £250 SOLD SOLD SOLD SOLD SOLD _______________ Nismo 555cc injectors { no picture yet) Good condition. Still nice and yellow, not faded or overly used. With rubber seals and end caps SOLD _______________ 1JZ head. JZX100 vvti. No cams. Lots of meat left on the underside ready for many skims. Came off a running engine however its not tested YET SOLD _____________ 1JZ EXEDY paddle clutch and flywheel Heat marks as usual. The paddle disc has some meat left on it. Really usable £350 ____________ Toyota chaser JZX100 Face-lift 2001 rear light clusters (pair) Very good lenses. One of them has a broken bit of plastic on the rear. But light still holds in perfectly. So cannot be seen. Looking for *********£150 the pair.********* Thanks +818084953097 WHATSAPP Call or message anytime. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
