For Sale 2JZ-GTE VVTI Engine For Sale
Thread in 'Parts for sale' started by mc_bob, May 3, 2018.
  1. mc_bob
    mc_bob Active Member
    ALL SOLD
    Engine:
    IMG_4377. IMG_4378. IMG_4399. IMG_4400. IMG_4402. IMG_4403. IMG_4404. IMG_4405.
    Engine is removed and I was planning to use it in the future. However, with the family potentially getting bigger, going in a different direction.
    I've had the engine 5 years in my Aristo. Last 3 years has run with Syvecs, monitoring Lambda, oil pressure, and temperatures. It had limits set and limits power until warm, and any fault would shut the engine down. Ive never had an issue saying this!
    The car had done 110000KM on the clocks. But at some point was changed to miles. It spent 100000 in an Auto standard 98 Aristo.
    Has 550CC Supra injectors installed.
    Engine valve stems let by. Common for all 2JZ, was going to replace when the engine was out. Will puff smoke on startup depending on how long its been left.
    Suspected oil leak but since its removed found its the bottom of the dipstick so a simple o ring fix!
    I haven't washed the engine purposely, not got anything to hide.
    Includes all air con pump and steering pump etc as pictured, not turbo or manifold (selling separately)
    Do have plenty of videos of engine running, and got parked up January this year and engine has been garaged since. Includes starter motor.
    £2100 Collected.
    #1 mc_bob, May 3, 2018
  2. mc_bob
    Manifold - SOLD
    IMG_4377. IMG_4384. IMG_4385. IMG_4386. IMG_4392. IMG_4393. IMG_4394.
    Been in use for 3 years. Had it skimmed and braced before fitting. Welding is shabby but has never been patched or cracked, and this is reflected in the cost. It includes the wastegate and fits 2JZ GTE engines only, not GE.
    Wastegate is a Greddy copy, but has a genuine 1 bar spring fitted as the stock ones are poor. Turbo control was good and no issues whatsoever.
    £120
    #2 mc_bob, May 3, 2018
  3. mc_bob
    Downpipe - SOLD
    IMG_4395.
    3" v band down pipe has flexi built in, connected to stock exhaust placement. All stainless.
    £80
    #3 mc_bob, May 3, 2018
  4. mc_bob
    #4 mc_bob, May 3, 2018
  5. mc_bob
    Holset HX35/40 - SOLD
    IMG_4378. IMG_4384. IMG_4385. IMG_4386. IMG_4396. IMG_4397. IMG_4398.
    Originally bought refurbished from Stav on the forum. Has been perfect. Always run with a large turbo drain (included) and measured input oil flow. Does not smoke at all and shaft movement is normal.
    Had an aluminium bend welded to intake and 3" Vband welded onto the rear for exhaust connection.
    Mint turbo and sounded brill!
    Has the 12cm exhaust housing which is sought after too.
    £350.
    #5 mc_bob, May 3, 2018
  6. mc_bob
    Everything sold except engine.
  7. mc_bob
  8. mc_bob
  9. mc_bob
    Offers accepted on motor.
  10. mc_bob
    Really need the space back, needs to go!
  11. mc_bob
  12. jon1200
    jon1200 Active Member
    thinking of going 2jz for next year. But if the price is good, i could probably buy it before i sell my my engine set up.
  13. mc_bob
    Feel free to drop through an offer. Got a Maserati on the drive that needs some money!
  14. mc_bob
  15. mc_bob
  16. bigmo1212
    bigmo1212 Member
    Have you still got the engine
