Hi guys. I have just bought a R34 GT4 with the RB25DE Neo 6 engine which I want to turbocharged. Has anyone done this conversion before? As far as I know all the DET parts bolt on the only difference is the higher compression ratio obviously being N/A. I've started sourcing the stock DET parts already. Any advice on oil return and vac taps would be helpful Thanks in advance
Was this the white one that was on eBay? You can bolt nearly everything on like you said, not sure if there is a blank on the exhaust side of the block for the oil feed but if not there will probably be a flat where you can drill into the gallery. Oil return will be a similar affair
