Hi, I have a set of E46 LCA's that im planning on putting in my 36 drift coupe, I have read that you need offset bushings to correct the caster. However is it true that installing 46 knuckles (spindles) pretty much does the same as the offset lolliepop bushings? Would it be a bad thing to run both 46 knuckles and offset bushings? Thanks guys.
