Alright fellas, I need advice ive got a fd3s rx7 with a 2jz, problem is the front shocks are on the bump stops (because of the added weight) I'm looking to buy a set of coilovers but I figured I'd need stiffer springs than normal but I'm unsure about spring rates. Can anyone point me in the right direction?
With my 1j fc i had 8kg and 6kg. Added some preload and dampers on hard it was still a bit soft and dipped in the front more than i liked. Changed to 10kg seems to behave a bit more positively. What coilovers have you got? If your planning on buying some it maybe worth talking to the company and seeing what they reccomend
Might be best to get it corner-weight measured first, that way you'd have some info for the suspension company to work with.
