For Sale BMW V8 M60/ M62/ S62 Turbo Kit
Thread in 'Parts for sale' started by Benzo, Oct 30, 2018.
  1. Benzo
    Benzo Member
    Gathered up all these Parts to Turbocharge my M62B44 based Project, I was extremely tight for space so downpipes & what is manufactured of the manifolds follow the profile of the Engine tightly, therefore it could easily be adapted to fit other cars.
    I have decided to stick NA & Install and S62 engine instead, my Gearbox and Diff are not up to taking Turbo power, this setup should easily achieve 500hp and 500lbft with basically no Lag from the Small Turbos.
    This kit includes everything from fuel pump, injectors, wastegates the lot.
    2x Saab TD04 15T Turbos
    New Tial 50mm Type dump valve & weld on fittings
    2x New Tial Type 38mm Externa...l wastegates & weld on fittings
    New DeatschWerks DW300 Fuel Pump (300LPH)
    New Twin Entry Bar & Plate intercooler
    New 8x Siemens Deka 830cc Direct Fit injectors
    Fuel Pressure Regulator
    2x New Larger Turbo Housings Exhaust sides for Better Flow (6cm)
    2x Exhaust side Flanges (3bolt Stainless)
    8x Head Flanges
    2x Part Built Stainless Manifolds & Collectors
    2x Stainless Downpipes
    2x Kevlar Turbo heat Gloves
    £1800+ of Parts alone. I am Open to Sensible offers.
    Iain - 07522976072
    44979646_2215292805407109_2122971475072778240_n.
    44944499_2215292862073770_7763295035541422080_n.
    44940913_2215292822073774_1359304102042927104_n.
  2. Benzo
    Benzo Member
    Monday Morning Bump.
    Forgot to list, 3Bar MAP Sensor & Boost control Solenoid also included.
    Added it all up again, close to £2K in Parts.
  3. Benzo
    Benzo Member
    All Sold
