Still needing some? I assume you’re after the ones which the coilovers pass through the centre of? I’ve got a pair off the car right now with good bushes?
The ones pictured above are for S14/15 R33/34 not for an S13/R32. Just be aware that the arms pictured above DO NOT fit an S13
Thanks for pointing that out in case I have to buy new. Any idea where I can source these that fit an S13?
Then you don’t need S13 ones. Do you even have an S13? Or an S14? Because if you have an S13 the only ones that fit are the ring type. Trust me on that
I have installed the S13 subframe into my Z31. I think I'll have to go with the S14 arm style ones and see how they fit.
But if you’re using s13 subframe and s13 knuckles and coil overs you’ll still need the ring type. S14 arms would hit the coilover. It’s like I’ve already done it
You've done the Z31 S13 subframe swap? The strut mounts in the car are further back than the s body though? No ring style will work as a result.
