Been debating this on and off for a while now so finally think it’s time to do it. Have lost interest in building this so someone else can enjoy it! This car has never seen the road or track. All parts off it have only been test fitted and are virtually new. I have pictures of pretty much every stage of this build and all the parts so if you need anything just message and I’ll send anything over (or there’s an album on my profile). Have access to trailer and van so could deliver shell and engine at extra cost. UK 200SX Shell - has been fully under sealed, full weld in comp spec cage by cageworx, painted inside and in engine bay, tubbed front and slightly tubbed rear arches, has had rust repaired throughout. I have the full V5 in my name and a folder with receipts for all the work carried out. Comes with OEM rear lights and stripped doors. - 2K Or Offers Parts Shop Max Competition Coilovers - 10kg/8kg spring rates. Have been greased, virtually new. - 850 ONO 1JZ VVTi engine imported through JDM Distro last April, comes with all ancillaries, engine loom. I have refurbed the engine and replaced all the baskets apart from the head gasket. Have also done a timing belt on it, put lightweight pulleys on it and a new AUX belt and also oil filter sandwich plate. Also comes with XCessive manufacturing engine mount brackets for S13. With a R154 manual transmission, also comes with a fully refurbed 6 paddle ACT Clutch and a lightweight flywheel from CG Motorsport. Also comes with a S14-R154 prop but can supply front half of S13 prop if need be. Flywheel is on the engine, with ARP Flywheel bolts. - 3250 ONO Chasebays Brake Booster Delete kit with in bay brake lines, brand new - 300 ONO Chasebays 1JZ - RHD S13 powersteering line and reservoir kit, converts to AN Lines Brand new - 250 ONO Vibratechnics Competition engine mounts for S13 - 180 ONO Parts Shop Max new Z32 Brake callipers front and rear with MTEC Front and rear discs (drilled and grooved) Includes 2 front and 4 rear callipers (twin Setup) brand new callipers, discs also new just slightly surface rust from sitting, callipers Include brand new pads - 650 ONO Sytec fuel pressure regulator kit with AN lines brand new - 65 ONO S13 - Z32 brake lines front and rear - 80 ONO S15 Dash conversion, has been cut slightly for cage. Comes with top and bottom panels, centre console, and glovebox - 200 ONO Bosch 044 fuel pump with torques swirl pot, with several AN fittings and roughly 3m of braided fuel hose for interior lines, all new - 250 ONO Kouki rear lights, with carbon centre garnish and lower panel, very slight damage to O/S lens - 400 ONO SRB Power Fibreglass roof panel, wrapped in black - 115 ONO SRB Power Fibreglass bootlid, with boot catches - 215 ONO Plastics 4 Performance full window kit, with front sliders, rear quarter window ducts and rear screen. Also comes with their cleaning kit and front window metal supports, never fitted or unwrapped apart from one front window - 500 ONO Brand new JR5’s 5x114.3 18x10.5, wrapped in brand new 265/35/18 Kenda’s - 325 ONO Link G4 Plug in ECU for S13 76 pin and early S14’s - unused still in original box and wrapping. - 900 ONO GKTech mirrors - 70 ONO Mocal oil cooler with braided hose - 100 ONO Full Apexi N1 Exhaust for S13 CA/SR - 200 ONO OEM S13 VLSD Diff - 40 ONO S13 CA Engine and Interior Wiring looms - 50 ONO Driftworks super low seat rail drivers side - 100 ONO Raybrig headlight lenses - 50 ONO Any questions feel free to ask! Collection from Ipswich on larger items, can post smaller things within question. {} {} {} {} {} {} {}
Hi mate, I might be interested in the engine setup if you still have it, could you send me a text - 07766680660
