This is my PS13 that I unfortunately need to sell due to lack of storage space, the engine has less than 4500 miles since it’s rebuild, full spec below. Fully polished and balanced crank Acl bearings brand new Arp head and flywheel bolts all brand new New water pump and all that 1.6 cosworth head gasket Hks high lift cams and adjustable cam pulleys Nismo 740 injectors recently flow tested Kinugawa TD06 with braided lines all fire proof sleeved Tial 44mm waste gate with fabricated screamer pipe Intercooler pipes welded instead of silicon joiners Link ecu Stage 4 competition clutch with lighter flywheel Walbro fuel pump R8 coil conversion 420bhp on high boost and 370bhp on low boost. No rust at all, dent in bonnet smaller than a 5p coin and one other paint crack behind the driver door. The exhaust has also slightly burnt the rear bumper so I heat wrapped the tip in black heat wrap. Other than that it’s very good for its age. It’s very rare to find a stock body PS13 let alone one with this spec. I have all the import papers etc and original log book. - It is on HSD coilovers - 17” 7Twenty Style 49 wheels, 225 R888R’s on the front and 225 Falkens on the back - Standard interior other than a sparco steering wheel, Tomei shift knob and a Pioneer touch screen which has Bluetooth or a usb to plug your phone in and play music - Original rare Carrozzeria parcel shelf speakers - Brick headlights - R33 GTST front brakes - Uncraked dash, but there is damage where a dash mounted gauge has been removed The body has 172,000km on the clock, that’s 106,000 miles Probably loads I’ve missed, so just text me and ask al I’ll help or update the ad £12,000 Based in Bedfordshire I’m rarely on Driftworks so for any more info it would be quicker to contact me on 07432153474 Thanks {} {} {} {} {} {} {}
Thanks for pointing that out, didn't notice that, I wasn't present at the MOT yesterday so I assume it was a mistake on their part. Its done approx. 1000 miles since the last MOT. Will get some engine buy pics, its recently had all the intercooler piping sprayed black and the duel rail and lines zinc plated.
