SR20 runs perfectly for 5 seconds then dies - injector pulse
Thread in 'Technical Questions' started by s13silvia, Feb 19, 2019.
  1. s13silvia
    s13silvia doughnut muncher
    Hi guys,
    anyone clued up on the likely cause of this?
    SR20de
    Runs perfectly for 5 secs then dies, regardless of throttle input.
    Do the same but squirt Easy-start into the intake and it keeps running.
    Fuel pump keeps running even once cut-out, pressure is nominal.
    So one would think 'injectors are the culprit'.
    When I unplug the MAF to put it into limp mode it runs consistently and wont die.
    Tried adjusting Timing etc. and made no difference, CAS can't be 180 as dizzy is keyed for one direction.
  2. BenRice
    BenRice Well-Known Member
    I think you've answered your own question - faulty MAF
  3. s13silvia
    See I thought at the start it would be that straightforward but everything i read suggests unplugging the maf takes all the sensors 'feedback' out of play; so just unplugging it doesnt automatically prove its the sensor at fault.. ive tried a spare and it performed same fault but ill buy another
  4. Cades
    Cades Member
    Stock ecu has like a ‘get you home’ feature, where if your maf is completely dead, engine will still run. You can check it at the plug with a multi meter.
  5. BenRice
    Could also be faulty MAF wiring too
  6. s13silvia
    Your are the f*cking ticket!! :-D
    Turns out it WAS the maf, it wasn't faulty as was working on the other car - but was the wrong one. Both were from a p10 primera sr20, both had same pins and sensor setup (different connector location albiet) but one from an earlier version one from a later; my ecu was earlier.
    So 17 quid later and months of going over my wiring convinced I made a mistake can finally be put behind me :p
