Hi all, UK engine now breaking for parts - mileage stands at 41260 miles. I only have left what is listed below, the rest of the parts have sold. Upper timing belt cover - £10 Lower timing cover - £30 Viscous fan TT - £60 Thermostat - £10 Lower water neck - £20 Starter motor - £60 UK 550cc injectors with fuel rail and resistor pack - £200 Throttle valve motor P/N 89632-14010 - £20 Throttle position sensor P/N 89452-33010 - £75 Timing belt tensioner and bracket (good bearing) - £30 Timing belt hydralic tensioner - £10 Crank and cam pulley bolts - £10 Knock sensors x 2 - £50 Oil pressure switch - £20 Lambda Sensor - £30 {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
