Hi! I have a problem with my RPS13. The car simply wont shut off, ignition stays on, unless I choke or kill it. Disconnecting the battery doesn't even work! I've narrowed it down to the EGI relay hanging, as I can tap it and it releases. Removing the relay, car runs and stops no problem, as the pump relay signal is directly from the ignition lock. No power at the pump power wires, (black/yellow and black/white) though. Any ideas why that is? It has to be getting power from somewhere to stay open, it only happens after it's switched. Any guesses? Bad ground maybe? Ignition on: 3-5 1.5v 1-2 12v Ignition off 3-5 12v 1-2 0v {}
