{} Nissan Silvia S15 Spec S Manual 164k kms - speedometer still in kms and Japanese 112mph limiter still in place MOT January 2020 Located in West Sussex Work CR-Kai wheels in bronze 17x9 et17 Apex / Driftworks CS1 Coilovers Adjustable rear camber arms Adjustable rear toe arms Japspeed tie rods with built-in rack spacers Tein rod ends Fully polybushed rear subframe and diff (StrongFlex) Welded stock diff (4.1 ratio) Exedy stage 2 clutch Competition Clutch lightened flywheel Driftworks braided clutch line Skyline R33 GTST brakes all round Hel braided brake lines Apex air filter De-cat Unknown brand cat-back exhaust Spec R style sideskirts Spec R style rear spats DC2 replica front lip Full interior Fly-off handbrake button Pioneer double din CD/radio Lower half of dash is glittery Wiring loom route through from the cabin to engine bay has been relocated properly to prevent the tyre rubbing it (common issue on low s-body’s). When I bought the car, the underside was wire brushed back and fully undersealed while the rear subframe and diff were out being polybushed. Pictures available of this, if needed. The car has been used as a drift car and weekend car only in my ownership but has been extremely reliable and I have driven to Scotland and Germany completely trouble free. The gearbox is the same as a 5 speed S14 box so if you wanted a sub 350bhp SR20det installed, this gearbox would be fine fitted. Already has a good flywheel, clutch and braided line. Bad bits Paintwork not perfect. Most of the passenger side looks to have been repainted with rattle cans at some point so it is very flat. Skirts and spats have been painted with rattle cans Spot of rust on n/s front wing. Slight surface rust on rear arches where they’ve previously been rolled and painted badly - none of the rust on bodywork has gotten any worse in the time I’ve owned the car. Exhaust blowing slightly near back box area Engine bay could do with a clean Work wheels need a refurb due to what looks to be the original paint flaking off. Please note - car comes on the bronze Work CR Kai wheels. Stock seats fitted - bucket seat not included and stock steering wheel and gear lever will be fitted too. Priced considering the bad bits and the spec. £6500 NOW £6000 {} {} {} {} {} {} {} {} {} {} {} {}
