{} {} S14.5 for sale I’m in no rush to sell so I’ll wait until a serious offer and near my asking price, spent a lot of money over winter getting this car ready and to look how it does. Compression test has been done by previous owner not even done 500 miles myself in the car with storing it over winter and doing a lot of work to it. 150 145 145 145 Engine- Bent cam sr20det. T28 turbo. Horsham stage 1a ecu. Modified standard cast manifold with 38mm tial external gate with screamer pipe. Full 3” exhaust system. Front mount intercooler. Turbo smart manual boost controller. Walbro fuel pump. Ally rad. Transmission- 5 speed box works fine. Extreme auto stage 4 comp clutch and lightened flywheel done about 300 miles. Welded auto diff (3.9). Steering/suspension/brakes- Hsd dueltech coilovers. Dw rear arm set. Dw front kinked tension arms. Modified subframe. Modified knuckles. Extended arms. Longer tie rods. Standard front brakes. Z32 rear set up with new discs, pads, handbrake shoes, r33 cables, conceptua conversion braided lines. Fully braided. Abs delete and pump removed. Interior- Dw super low seat rail. Bride rep bucket seats Boost gauge, oil temp and water temp gauges can be included as they aren’t wired up yet Fly off handbrake button. X2 takata harnesses. EPR racing steering wheel D1 spec carbon gear stick Full interior put back in apart from rear bottom seats, back rest is sat in but no base due to harnesses Battery relocated to boot. Exterior- 25mm vented wings. 50mm rear overfenders. Carbon fibre dmax bonnet Origin lab racing line kit. LED rear lights Adjustable custom made front bash bar Full exterior repaint in Mitsubishi rally red - not even 200 miles since done Limo tints rear SSR Minerva's - 5x114.3 Fronts-17x10 et15 (4" lip) Rear-17x12 et-9 (6" lip) Offsets may be off slightly but that's what I got using an offset calculator. Not long been split, blasted and polished. Barrels powder coated black. Sealed and put back together, no leaks on any of the wheels. Mot until April 2020 Faults- Crack in windscreen, I’ve already had this done a month or so ago and my luck got me another cracked screen Slight vac leak which I haven’t had time to look at but it’s not a big issue. Previous owner had bolt in roll cage so some cut outs on the dash which are just a little eye sore but not bothered me. Slight crack in the bumper from before the bash bar was made to hold the bumper up Few other things in the interior could do with a tidy up if wanted like the speaker surrounds etc easily achievable. Some little work and you will have a phenomenal car Looking for £9995 Car is located in Grimsby, Lincolnshire Collection only. 07305901388 if you have any questions {} {} {} {} {} {}
