right guys Give me a list of what’s required I’ve just removed my 2.9 ratio large case diff from my 323 coupe and I had panned to put the 3.38 in its place Noticed shafts are smaller and shorter, I looked at swapping the cups but they are longer and won’t lock in as the ring grove is in a different place Can the swap be done or where do I get a large case 3.38
2.93 diff is medium case , large case in m3 evo stuff , you needs shafts and rear half of prop to swap to small case
I have a compact that I’m breaking but looks like none of the parts are swappable Where are you located then
compacts have different rear subframe altogether , they more like e30s , I m in wales but can post if needed
Yeah as I stripped parts last night where I noticed the shafts being shorter. What all have you got ?
I defo got rear prop for small case , need to check if got any shafts left , I ll drop you a message tomorrow
