2002 BMW 330ci (e46) Sport, in metallic black. Manual 5 speed. 130k miles. MOT Jan 2020. Two keys. Factory Shadow line trim (no external chrome). Factory rear LED light clusters. Factory M Sport steering wheel and kick plates. Angel eye headlights Black leather seats with electrically operated fronts. MV1 Genuine Staggered alloy wheels. Powered M3 style door mirrors. Eibach Pro-kit lowering springs, on standard shocks. 3.5mm aux jack fitted to factory unit, allowing external sound source. In my ownership since 2017, I have dealt with the following issues: Replaced discs, rear drum shoes and pads all around, bled with ATE Type 200 performance brake fluid. Replaced both rear shocks. Replaced rocker cover gasket with OEM BMW gasket. Replaced oil filter housing gasket. Replaced CCV swirl pot and pipework. "02 pilot" mod, improves the engine vacuum to stop oil passing the piston rings, resulting in zero oil consumption. All appropriate lights show up on ignition and disappear as they should following start up. Bodywork showing the usual wear of a 17 year old car, but there are no signs of rust. Rear subframe appears free of cracks too. Stacks of receipts and a recent oil change. Car has only done 10k in past two years, as I'm 2.2 miles from work. No part-ex or swaps. £2000 no offers. Located in Cardiff Also available, fully polybushed rear subframe (never used since polybushed) and professionally welded 3.38 diff (unused since welded). £300 for both. Was going to build a drift car with it, but plans have changed. {} {} {} {} {} {} {} {} {}
