Got this awesome bit of kit up for sale. As the title states, this is a Holset based turbo which packs the following specs: - 64mm inducer, 86mm exducer billet 7+7 blade compressor wheel with extended tip technology (largest off the shelf compressor inducer for a HX40 is 60mm and no extended tip technology) - 76mm inducer, 64mm exducer 10 blade turbine wheel (higher flow over the common 12 blade version) - Oil and water cooled core - Ball bearing (!) - 16cm (~0.90 A/R) T4 Cast 347SS Turbine Housing This turbo was used on a 2JZ which made 600bhp and 800Nm tq @ 1.7 bar. Full boost was had by 3500rpm! Usual surface rust and dirt here and there from use, but overall very good condition. Turbosystems officially rate this as a 750HP turbo, but it will do well in excess of this on the right engine with the 64/86mm comp wheel. FYI, a standard 60mm/86mm HX40 flows ~72lb/min max (about 720bhp), so with a 4mm larger inducer, ETT and slightly slimmer hub, this unit will flow way more. I would like to get £635 plus postage for this. Any questions, please feel free to ask. Photos - please note what you may see in some photos isn't damage in places to the compressor wheel, but simply material removed for balancing. {} {} {} {} {} {} {} {} {} {} {} {}
Decided to sell with the original turbine housing, so now asking £635 plus postage. Wil get new photos up when I have a moment.
