Up for grabs is a complete mazworx SRVQ conversion kit. This contains everything you need to swap out your standard gearbox for the 350z transmission. Contains the following : Transmission from a 2005 350z with supposedly 50k miles. Shifts fine no crunches or unwanted noises. Bellhousing cut off and mazworx one fitted with new gasket. Input shaft shortened as per instructions. One price propshaft (uprated 3" steel option) Crossmember Gktech short shift instead of the mazworx one. Personally I preferred the feel of the gktech shifter. New Nissan pilot bearing and installation tool. A big advantage of this kit is that you can use your existing clutch, gearbox mount and slave cylinder. Bear in mind this is obviously used so has usual surface corrosion and blemishes but all works perfectly. Located in Southampton. Buyer to arrange postage or I can deliver if not too far. Thanks for reading. Price £1800 Bear in mind it will cost you close this just to import the kit alone with shipping and import costs!!
