2uz water flooded disaster HELP PLEASE GUYS
Thread in 'Technical Questions' started by gt4tosupra, Mar 4, 2020.
  1. gt4tosupra
    gt4tosupra Active Member
    Hi guys not been on here for probably years but I know u guys are a pool of knowledge,, so,,,,, I bought a Toyota Tundra gen 2 rwd truck, yes it skids but I didn't buy it for that,, it's my work truck 2uzfe vvti engine 4.7,,, last Monday I drove through water that was deeper than I thought, splashed water into the intake long story short,, the engine cut out quietly,, I've begun a strip down,, engine will now turn on the crank but stops at a certain point,, it'll turn backward ad as well,, until stopping at the point again,,, now main question is for now,,
    Is the 2uzfe vvti block the same as a.non.vvti block,, ie if I have bent rods could i joust but another engine,, non vvti as there's a few in this country,, and swap over?
    Are the rods the same as 1uz and 3uz as someone has said yes but would rather double check that
    Cheers in advance
  2. gt4tosupra
    Photos 20200301_170215. 20200301_164917. Screenshot_20200304-150709_Video Player. 20200224_103737.
  3. gt4tosupra
  4. Nite_Shayde
    Nite_Shayde Active Member
    Might have better luck if you can post in the '1UZ, 2UZ and 3UZ Forced Induction Technical' or '1uz-fe swaps uk' groups on Facebook, some knowledgeable folk over there
  5. Andrex
    Andrex Member
    This may not be the best advise in the world but when I hydro locked my sr after head gasket failure, I pulled the sparkplugs and cranked it and watched all the water shoot out. Put it back together and then it fired up. Got me home that day. Albeit a bit smokey!
  6. BreadBin
    BreadBin Rough Tonguer
    It's a bit late for that - the fact that the motor is locking up sounds like it's bent a conrod.
  7. gt4tosupra
    Defo too late for that yep,, 2 holes in block,, I've almost got 1 head off,, gonna inspect it and take it from there,, if the heads are ok then Ye if I can get a non vvti block from the UK and is the same as the vvti, then that's best case scenario
  8. gt4tosupra
  9. gt4tosupra
    Oh and...... Screenshot_20200308-102747_Video Player.
