Selling my syvecs s6gp with complete harness and sensors for a 2jzgte vvti. Was sent back to syvecs to have the traction control and antilag added reading wheel speed sensors and has had a lot of time spent getting the tune spot on. Was set up on a small single turbo setup Needs 5 wires cut and spliced into the body loom that's it to run everything, I have the body plugs cut of the car numbered to make it fool proof £1750 and would prefer collection from lowestoft nr32 area but can post at your own risk Description from syvecs below about what it can do and will add pics later The S6GP ECU offers an extremely high level of precise engine management control. The twin processor unit uses a high speed RISC processor for code execution and an additional large FPGA for high speed engine position tracking, allowing the scheduling of code to be independent of signal patterns, increasing flexibility, efficiency and accuracy under transient conditions. This powerful combination also allows advanced control algorithms but yet easy to map for the end user. The S6GP is the Backbone to our Highly Popular PnP Board Technical Specification 100 MHz full duplex ethernet for connection to PC for programming and data download 1 CAN 2.0B interface 16 general purpose analogue inputs: - 4 5V/bipolar, sensor/sync/speed, programmable trigger voltages - 4 5V/Thermistor, sensor/sync/speed, fixed trigger voltages - 4 5V sensor input - 4 Thermistor sensor input 1 NTK/LSU lambda circuit 1 K-type thermocouple circuit 1 knock input 16 low side driver outputs: -8 injection outputs (Max 10 amps) -8 ancillary outputs (Max 5 amps) 6 logic level ignition outputs (5 or 12v) 1MB Battery backed internal logging memory 6 to 26v input voltage range with reverse polarity protection 2 regulated 5V sensor supply outputs with protection Unregulated sensor supply output which tracks the ECU supply voltage 5 Seperately protected sensor and communication ground inputs Dimensions : 181 x 160 x 51.5 mm
