Hi, got a BMW E36 with what’s believed to be a driftworks hydro. Wilwood .625 cylinder driftworks lines etc. Intermittently the hydro won’t lock the wheels and does take some force to do so, other times it’s okay depending on surface etc. When I first bought the car the hydro was spot on over time it’s got worse. Is this a simple case of bleeding or will the fork need adjusting if so what direction? Been a few times I’ve pulled the wand into an entry and it hasn’t locked and just slowed the car down where as other times no problem at all. Seems to require much more force to lock than before. Pads are good etc. Thanks in advance
