I've owend this car for 2 years. I bought it from England, now the car is Italy. Car is ABSOLUTELY READY for drifting use. Engine runs great, more than 400hp 520nm only 1bar of boost. Drivetrain: Fully Rebuilt RB25DET Gearbox, All Synchros and bearings replaced by RK tuning 2 yers ago. XTD Lightweight Flywheel (skimmed) CG Motorsport custom 6 Paddle clutch Kaaz 2 ways diff R33 Driveshafts Footwork: Driftworks Cs2 Coilovers Driftworks Geomaster front hubs Relocated Steering rack / fresh sub frame (+20mm forward) S14 LCA's Tein Rods & ends Tie Rod Extension Spacers Full Apex Lower arm package Solid Rear sub-frame mounts + Poly Diff Bushings Z32 Rear Brakes R33 Aluminium front brakes Braided & replaced brake lines all round (Routed in-car) Enkei Circular 17x9 Federal 595 RSR’s front/ i have 3 extra set of 17 wheels for drifting Hubcentric Spacers & DW wheel nuts Engine: ngine taken apart and checked, put back together with acl main and rod bearings, gapped rings, arp head studs, cometic head gasket. Head has been resurfaced, completely checked over, new valve stem seals installed and oil drain kit fitted. Trigger system converted to crankshaft sensor, link g4 storm ecu, with afr, egt, oil temp and pressure, and fuel pressure wired in. ross performance crank triggering kit, with race damper extra head oil drain line tial 44mm exsternal wg mamba gtx3071 turbo 750cc nissan injectors mishimoto fmic drifshop oil cooler afr, turbo, oil temp, water temp, rpm, gauge inside the car Price: 17000€ Francesco, +39 339 48 62 872 feel free to ask for more photos, videos or info. {} {} {} {}
