Hi, Been using this as a daily for the last year and it’s been a reliable and comfy cruiser, but time for something different. So it’s a 2002 with the later M52TUB28 with twin vanos, not long ticked over 100,000 miles. Only issue I had in my years ownership was a split PS hose. Genuine BMW Facelift angel eye Headlights included (need refurbishing including adjusters) also not plug & play. B cables diagnostic software and cables included. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} BAD POINTS MOT has just run out Slid out 3 weeks ago, had a light tap on the front corner. ABS, DSC & TC lights on. Diagnostics scan in photos - shows Front Left wheel sensor - Delphi ones can be bought on ebay for £35. Also shows low voltage from when it needed a battery a few months ago. Rear suspension is half airbag, half spring. Has a very slow leak, so if you leave the car sat for 4 days or so, the right side drops right down. Pumps straight back up as soon as engine starts though. Rear arches and sills going Rotten. Cracked washer bottle for headlight washers (I have removed the headlight washer fuse from the glovebox fuse box) Dodgy bonnet switch was unlocking car and setting alarm off (unplugged and all working again - replacement is cheap if your bothered) Could be put back on the road, but probably going to get stripped for it’s engine & ‘box. £450ono, cheers, James
