Got some parts left after selling jzx. JZX110/JZS171 (late model 1JZ VVTi) MAF. Denso DMA-0114. New unpacked. 90£ shipped. 1JZ/2JZ Uprated Alternator. 180 Amps. Comes with bracket, spacer, bolt, plug and longer aux belt. Just test fitted and ran for 1 day. 160£ Shipped. SARD Jet Pump Killer. Uprated venturi valve for JZX110 JZS161. Brand new unopened. 80£ shipped. 1JZ VVTI Injectors. Not tested, bought from here but never used them. 50£ shipped 1JZ VVTI Injector Seals. Brand new. 30£ Shipped. Greddy Intercooler (LS spec) JZX110 I-4 pipe. The one next to throttle body. 50£ shipped 1JZ VVTI Water pump housing (used, changed over to new at 100k km) - 35£ shipped 1JZ VVTI Water Pump (used, changed over to new at 100k km) - 25£ shipped 15mm Spacers, 5x114.3. one pair has extended bolts. Toyota bolt thread. 50£ Shipped. Stock JZX110 Intercooled. Great condition - 50£ shipped. Used 1jz vvti coil packs. one of them was misfiring so ended up buying new. could be leads or coilpacks themselfts. 40£ shipped for all 3. JZX100 Bosch Fuel filter - 10£ shipped. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
Some kit that someone from forum makes them. took it off and changed over to stock because was selling my jzx.
