Freshly built & modified Garrett GTX2867r Gen 2 Turbo spec below - Custom forged billet GTX2867r Gen 2 compressor wheel with extended tips, larger inducer trailing angle & smaller root design to improve flow - Inconel 713c GTX2867r G2 turbine wheel - New bearing housing, ball bearing cage & seals - New stainless turbine housing (.64ar) - 3” Intake & 2” outlet anti-surge compressor housing (standard replacement from OD) - Built in 1mm restrictor Compressor spec: 50/67.4mm (71mm ex. tip exducer) Turbine spec: 53.8/47mm Turbine housing is T2 flange with 5 bolt outlet. Wastegate actuator is included Component and VSR balanced, ready to use Rated for 430hp £800 {} {}
