For sale is my Toyota Chaser JZX100, i am the only owner since it has come into the UK. Imported in November 2018 Grade 4 at import 155000 Km/96000 Miles Full timing belt kit including water pump new vvti gear, crankshaft gear, front main seal, cam seals, rocker cover gasket and fuel filter in 2019 Oil and filter has been changed twice a year and always used Fuchs Pro S 10W50 Funk Motorsport Air filter Crest Motorsport Intercooler kit Dw200 Fuel pump with inline fuse and relay Custom catback made by StyleDynamics CD009 gearbox using the serialnine bellhousing kit and billet crossmember Serial nine shifter Serialnine flywheel Southbend Stage 3 (Exedy Friction plate) Custom propshaft made and balanced by Heathrow props Kaaz 2 way Super Q version - fluid changed every year BC Racing coilovers Strongflex Diff, subframe and rear hub bushes as well as new spherical hub bushes, front and rear anti roll bar bushes, rear upper control arm bushes, front castor arm bushes New discs and pads all round Underneath and rear arches undersealed, as well as painted subframe, diff and driveshafts. Recaro’s from a galant vr4 reclining and on custom sliding rails for adjustment Factory S2 lip kit I have a lot of paperwork for more or less every part, service, labour invoice etc including original import/auction documents. Bad bits The interior trim around the window switches is starting to peel a bit The paint is wearing thin in places on the front bumper and lip kit and the rear bumper has some lacquer peel, and wing mirrors are in base. However, the bodywork is very straight in terms of dents. Please do not hesitate to contact me for anymore pictures for example, the documents and papers or a video of the car that i can send over whatsapp, however only serious enquiries please! I am asking £19000, please do not bother with sending me low offers i will not respond. I believe its a fair price by what the rest are up for at the moment and with the spec/parts and invoices you can see this has had a lot spent on it. {} {} {} {} {} {} {} {} {} {} {}
