Welcome to the sale of Mazda RX8 with an engine from Nissan Skyline with the designation RB25DET NEO. The car is 100% functional. Sheet metal machine in very good condition. The engine is in perfect condition and got 330 HP. New candles and coils. Timing done right after the swap. It doesn't even take a gram of oil. Oil changed every 9,000. Swap made by the master from RB / JZ Radek from Thunder Race. Mazda is perfect for daily, because it can be gentle from the lower revs, but when pressed, it is hot as hell, which gives a lot of fun to drive. Everything is dressed up for the EMU. New summer tires were purchased for the car. New battery. AFR indicator. The car sticks to the road. Liability for a year Review over half a year CAPACITY STILLED IN PROOF! He sells because he needs a bigger car. If you have questions, message or call +48530666325 / mmaallyy131@gmail.com. regards {} {} {}
hey mate what about trans what did you use fior it ?? oem 6 sp mazda or oem rb 5 sp i am curious mazda 6sp can work withoutproblem in so much power
Manual 5 from Mazda Rx8 and it's ok and still can handle more Nm with no problems, I heared 6 are less durable.
[QUOTE="mmaallyy, post: 2757331, I heared 6 are less durable.[/QUOTE] 6 speed is similar with nissan s15 spec r 6 sp 6sp manual trans stronger than all 6sp is from honda s2000
Anyway 5 gear from Rx8 is ok, friends had 2JZ and also V12 from Toyota and 5 gear had no problems with Nm. 6 sp from Mazda will make gears very short.
