Imported in 2015 Just got it through a genuine mot last month 158,444km Link ecu 330hp @ 1.2 bar Ran on v power with millers and redline oils Tomei rocker arm stoppers Splitfire coil packs 750cc Nismo injectors Greddy intake manifold Tomei M7960 turbo Greddy boost controller Fancy intake pipe (never seen one like it before) Blitz sus filter Apexi bov Swirl pot and genuine bosch 044 pump Greddy radiator Tarrks power steering pump relocation Oil cooler and mocal filter relocation Oil catch tank Relocated loom Divorced downpipe Modded r32 shotgun exhaust Cusco dash dodger cage Modded hubs good angle Gktech rack spacers Dmax track rods All front and rear arms adjustable Japspeed superlock front tension rods Japspeed superlow rear toe rods HSD coilovers (seen better days) R33 front calipers R33 5 bolt diff Os giken super single clutch Driftworks engine and box mounts SSR Vienna splits Nismo power brace HKS chassis rail brace Fabricated rear crash bar with jacking point Vertex rep wide body Type x rear lights Raybrig hid headlights S14 seats Genuine nismo knob Cube shifter Old school Personal wheel, was told its from the 80s Paint and the fiberglass isnt in the best condition but never bothered me. Pop ups are fixed position. Passengers side window doesn't go down. I got a bit too carried away with the rust converter the front towers, they aren't bad, just me being paranoid. Cage could do with being bolted down properly. I love s chassis but the prices of these rafts are stupid, needless to say im not getting left behind so £14K {} {} {} {} {} {} {} {} {}
Hey pal, how does that turbo run? Full boost rpm etc. Got any dyno printouts? Ps only asking as I have that same turbo but haven't fitted it yet lol. Cheers.
Its a bit laggy, 1.2 bar comes at around 6000rpm but it has a little more headroom than the .64 2871r. I have a nice mani, ewg and avcr, sitting here which would have helped but change of plans. Im sure you know that Tomei use td0 series and sprinkle their magic on it, its a journal core .72ar, correct me if im wrong. Sounds great, decent punch, good top end and nice bit of jdm bling.
5000 to 6000 is responsive but i can check the gopro tomorrow, better mani would help. The graph above looks to be the ideal scenario, 22det or vet, cams, manifold, probably adjustable cam gears too
I rebuilt my one with billet core etc and I've welded the wastegate up to go external gate on a ported stock mani in hope for something magical. But its just rare coming across someone that's using one which is why I was curious. Tomeis website graphs are meaningless for the average sr.
If the car doesnt sell I'll weld it up too and run external, would be interesting to hear your results if you beat me to it. My mapper advised better boost control was needed so you're on the right path.
I don't have the best photos, no access to a ramp but i'll dm you what i have, its pretty good, its not smothered with underseal so you can see exactly whats going on.
