All manual RWD nissan gearboxs. Condition is as stated, no b/s Contact Details: email; info.ums.dyc@gmail.com Tel/Text; 07398 919 095 Nissan, Manual. RB Gearbox. Large case from a R33gtst / R34GTT. Low mileage, silent and drives smooth. The car came totally standard from japan so I very much doubt it was abused there and it was perfect in my possession. No play in the input shaft. No leaks. This will fit any RB engine and it is the RWD box, obviously the 4wd/gtr box is different. £1600. Nissan VG30 Gearbox. This is a popular gearbox to put behind an SR and internally it is the same as a RB box. Handle power well (north of 400 no issue), I have an adaptor plate I could copy if there is genuine interest. The place I got it doesn’t do them anymore. This gearbox is from my NA z32 300zx road car. No drift days, just normal driving. £1400 Nissan RB small case gearbox rear wheel drive. Removed from a r33gts (none turbo). Internally this is basically the same as a SR gearbox. Obviously has a different bell housing, otherwise it’s the same gearbox. I’ve priced this the same as a SR gearbox as a result. £750 Nissan L Series gearbox, from a 198x C32 Laurel, good manual box. £500 SR20det 5 speed gearbox. Good box, took it out a pretty standard (no power mods) road s14 that was rotten. No bad noises. Works as it should. £750 SR20det 5 speed box. Crunches into reverse. Tired box but goes through the gears and works. Changes up and down the forward gears fine. £450
