For Sale S14 S15 SR20VE parts clear out
Thread in 'Parts for sale' started by speedingmofa, Jun 9, 2022.
  1. speedingmofa
    speedingmofa Member
    Hi guys, got loads of parts here.
    Small parts i can ship to UK no problem, but the large/heavy ones I can only ship to the rest of the EU due to cost. Of course this is up to the buyer, but shipping out heavy parts to the UK is very expensive due to Brexit.
    For pictures, send me a PM and preferably your whatsapp to exchange pics and details.
    PRICES ARE IN EURO
    All prices are + paypal fees or send as friends
    S14
    Cast turbo manifold 40
    Igniter chip 50
    ABS ecu 20
    Trans bracket 20
    OEM Zenki grill red 20
    OEM Zenki steering wheel+airbag+spring vgc! 70
    New EBC red stuff rear pads $OLD
    Bybakits JDM navan rear bumper (slight tear) 80
    OEM S14/A euro rear bumper red 100
    New RHD Twin gauge holder - A pillar 20
    Engine mount brackets L+R 50
    Zenki MAF 69F00 $OLD
    OEM Knock sensor+new loom 40
    H-dev stage 1a chip JDM Zenki 69F0x 80
    Turn signals L+R 40
    Corner lights L+R 30
    Aftermarket FPR conversion adapter 10
    OEM recirc valve and fittings vgc! 30
    New Supertech turbo viton valve seals 20
    OEM camber bolts 15
    S14A driver airbag, no cover 20
    S14A front bash bar 100
    Headlight+wiper stalks 50
    Various switches 15
    OEM coolant bottle $OLD
    S14A OEM windshield fluid bottle + pumps 50
    Zenki headlight chassis brackets 50
    OEM engine undertray $OLD
    Rear subframe + all arms $OLD
    Rear calipers + discs $OLD
    Rear handbrake cables $OLD
    Transmission shifter fork+ new hardened pivot ball 50
    S14A OEM body kit z-edition, kouki skirts+caps, JDM front 1250
    New Manley Conrods SR20 475
    CP piston pins sr20det new 80
    Nismo 550cc 4x $OLD
    S15
    OEM crank pulley 80
    OEM intake manifold 50
    OEM throttle body 60mm + TPS 80
    OEM IACV / idle valve $OLD
    OEM girdle 40
    CAS minus disc+sensor 50
    SR20DET Water outlet 40
    SR20DE Water outlet 40
    Random
    SR20VE intake plenum 40
    SR20VE cooling lines/thermostat 50
    SR16VE in/ex camshafts 300
    R33 half shaft (long) 100
    R34 GTT brake discs 310x30mm 30
    NRG steering wheel (like new) 50
    Z32 TT diff stub axles 50
    Billet slim fit P12 CAS+SR sensor 350
    Shotgun Y-pipe 76mm in/65mm out 20
    350Z inner tie rod new 10
    2x Steelies 15x7J winter tires (5mm) 30
    BBK Fox body 70mm TB+TPS 80
    R33 GTR Spec-V cluster+pigtails 450
    Holset HE400 new T3 TS 16cm 650
    P11 SR16VE complete head 1000
    T30 SR20VET complete head 1600
    P12/T30 oil pump + pick up 150
    P12/T30 CAS 200
    540.
    540.
    540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540. 540.
    #1 speedingmofa, Jun 9, 2022
  2. crazyae86
    crazyae86 Well-Known Member
    hey mate
    i am after
    s14
    s15
    please text me for more details
  3. speedingmofa
    speedingmofa Member
    Lots of parts sold, added a few new items!
  4. speedingmofa
    speedingmofa Member
    S14
    Igniter chip 50
    ABS ecu 20
    Trans bracket 20
    OEM Zenki grill red $OLD
    Turn signals L+R 40
    OEM camber bolts 15
    Headlight/wiper stalks 30
    Various switches 15
    Rear subframe + all arms + arb $OLD
    Rear knuckles + 5 studs $OLD
    New CP piston pins sr20det 80
    Nismo 550cc 4x $OLD
    S15
    OEM crank pulley 80
    OEM throttle body 60mm + TPS $OLD
    OEM girdle 40
    SR20DET Water outlet $OLD
    Random
    SR20VE throttle body $OLD
    SR20VE cooling lines/thermostat $OLD
    SR20VE exhaust manifold 40
    SR20VE 4x 333cc 40
    R34 GTT brake discs 310x30mm $OLD
    Z32 TT 32mm diff stub axles 50
    P12/T30 SR20VE/T oil pump + pick up 150
    P12/T30 SR20VE/T CAS 200
