Toyota Mark II Tourer V manual 1997, 200k km (in daily use will rise) Registered April 2020 £24000 (without Recaro SR3) open to some negotiation J2XSY plate may be included - original reg P192 GPF Engine & Drivetrain 1JZ 2.5 VVTI Link G4X plugin making 400hp/400ftlb CT15B hybrid turbo billet comp wheel @ 1.5ish bar peak Bosch 730cc injectors AEM 340lph fuel pump Greddy front mount & pipework 3” down pipe and full exhaust KTS intake kit + recirc delete Vibratechnics engine mounts Koyo rad Mocal 16 row oil cooler and HEL thermo sandwich plate Factory oil cooler delete, coolant line simplification engine bay wiring simplified. VAG coil conversion with new wiring loom. Just had genuine timing belt+tensioner, water pump, cam cover gaskets, front and rear main seals, cam seals, various o-rings etc oil leak free. Also replaced the expansion tank and coil pack cover while I was at it. TRD short shifter Cube speed solid tripod bushes Exedy Carbon-D twin plate carbon fibre clutch and flywheel assembly (Can’t stress how amazing this clutch is, OE feel not a hint of judder and easily 500ftlb capable) New pilot bearing New gearbox input seal KAAZ 2-way super Q LSD Strongflex diff bushes New output flange seals Wheels Desmond Koenig Specials 18x9.5 front et35 with 10mm custom made hubcentric spacers to suit toyota hubs and these wheels only. 18x10.5 rear et35 Goodyear eagle F1 assy 5 all round Suspension/brakes BC coilovers Hardrace rear hub spherical bearings Hardrace front ball joints HEL braided lines Megane brembo 4 pot front calipers 365mm ISF discs WRX rear twin pots New rear discs, pads, handbrake assembly a month ago Exterior Vertex style front splitter and side skirts. Not sure on the rear lip / over bumper but is roughly vertex style. Bodywork in good shape, dent in the bonnet, in the front wing and stone chips on the splitter. Paintwork polishes up nicely, would benefit from a few touch ups here and there. The car was painted black at some point in its life in Japan; I have some images from when it was in japan and it was only black. Door shuts and underside of bonnet and boot are black; engine bay and under carpets etc is white. It's an S1 car but has been fitted with the S2 bootlid and proper tourer V S2 rear lights. I sourced and fitted new genuine wing markers as they had been removed before. Interior Won’t come with Recaro SR3, stock seats will be fitted. Vertex checker steering wheel Interior plastics dyed black Carbon trims have been sanded and relacquered Stack gauges - boost, AFR, oil pressure and temp Factory amp upgraded, 8” sub in the shelf and door speakers upgraded. Sony single din bluetooth HU. G corp checked floor mats All electrics work perfectly - AC is ICE cold, its amazing! I use the car every day March thru October and have never had a single issue with it. Most of the engine mods and all engine maintenance, timing belt, link ecu etc were fitted over last winter. I’ve easily spent over £11k on it over the last couple of years since registering in 2020. I'm sure theres a lot that I've forgotten. Open to PX for something PS13-ey or E30 maybe... try me! PM on here or whatsapp me on O7858 zero five three zero two five {} All images on imgur album here, can get more on request. imgur.com/gallery/rmFpH5p
Thanks for the offer mate but not really my cup of tea. Still semi open to PX but I've started looking at going top mount turbo with it and got some other bits in the pipeline so no longer for sale really.
