Garrett T28 converted to a GTX2867r Gen 2 Turbo specifications: - Point milled GTX2867r Gen 2 compressor wheel - Inconel 713c GTX2867r turbine wheel - Ceramic dual ball bearing cage with brass ball retainers (upgraded over standard GTX2867R) - O-ringed backplate - Reprofiled T28 compressor housing - Built in 1mm restrictor - .64ar T2 flanged 5 bolt outlet turbine housing - Mild internal wastegate port to provide precise boost control Component balanced + assembled cartridge balanced & tested on VSR Compressor size: 50/67mm Turbine size: 53.8/47mm Direct bolt-on fitment for SR20/CA18 capable of producing up to 450hp while providing superb response due to the light rotating assembly. One of the best bolt-on no messing turbo upgrade available. Will work with any T2 flanged manifold An actuator can be included if required, feel free to enquire via PM £780 Available for cheaper on our official online store; onboost.net {} {} {} {}
