Toyota Supra MKIV Big Single Turbo fully built race/track/drift car, Spec as follows: Original 6 speed manual TT car Custom Cages Certified welded in multi-point cage Sparco Pro Racing seats Schroth Racing 6 Point harnesses. HKS 272 cams HKS CAM belt Oversized valves Cosworth pistons Carrillo Heavy duty rods Brand new cylinder head Brand new block Twin external water-cooled trial waste gates Borg warner 400 sx3 82mm turbo Arp head studs Arp main bolts Hyper tune intake manifold with twin fuel rail 6 x ID 2400 injectors 6 x ID 1200 injectors AEM water methanol kit PHR 200 A alternator PHR power steering relocation kit 4in Front mounted intercooler Front mount oil cooler Oil filter relocation kit Syvecs S6 ECU Launch control and anti lag software 8 selectable maps Battery relocated to rear of car Fuel lab pressure regulator Triple in tank pumps V160 6 speed gearbox fully overhauled Exedy hyper triple plate clutch AEM ignition amplifiers PHR coil packs Glass headlights Defi gauge set Mishimoto twin fan aluminium radiator K sport big brake kit 356MM front K sport big brake kit 320MM rear Adjustable drift works coil over suspension Over £100k in receipts and invoices over the past 10 years of ownership. 1,000+ bhp with Dyno printout. Car is located near Thetford, Norfolk. More pictures available upon request. The car is not road legal so for off road/track use only. {} {} {} {} {} {} {}
