2JZ PARTS/CELICA DRAG /PRECISION TURBOS/PMC/SAMSONAS/FUEL REGS/EXH INLETS/MANIFOLD/JR WHEELS & MORE
Thread in 'Parts for sale' started by OW04NED, Nov 9, 2017.
  1. OW04NED
    OW04NED New Member
    west mids
    2jz parts/precision turbos/manifolds/inlets/fuel regs/celica drag shell/wheels & more
    ok we have a fair few bits off a few projects and cars we stripped for various reasons here at mb developments so time for a sort out
    precision 6466 gen 2 billet roller bearing turbo for sale removed from my own car/v band inlet and 3inch v band out let .82 rear housing/item is used but perfect working order no noises/no smoke or any signs of oil at all and only just removed so fully tested only thing worth mentioning is there is some minor marks on the intake blades minor and hasn't affect turbo in any way just worth mentioning/complete with billet -10 an oil return and correct size oil restrictor fitting all complete £1200
    97FA4A03-AF7E-40B9-B384-8D1B5CD131B5_zpspitbs68j.
    409AABE7-3E1A-41F3-A9ED-76AFCB1291DE_zpsz4fpwuvd.
    0554B78A-CC08-4D3C-AD27-8A659A327A48_zpscvgvlfxa.
    7440DCE8-089A-46EB-8772-34492725B2CA_zpsr1wmqjaa.
    68FA2DA0-8645-480A-BF91-582213EBB8F3_zpszcjdnqeg.
    671E0B4F-B226-41BD-B11B-37FD428F8FB0_zps2w9vcglg.
    B794D155-BEC1-44CB-927A-DBC361503F63_zps38f8rqp9.
    E1C333F3-039D-433F-93EF-FC3BD5642E5C_zps3zeqgcxp.
    90DF2E17-6E43-4452-9588-570A4762CE6D_zpsqjn8xlun.
    BD85D682-014E-4CD3-B6BF-5C2980491AF0_zps8qy7lk9q.
    Turbo smart 44mm ultragate compact waste gate very little use only run up to 1.5 bar only very good con with sealing Collier and v band clamps does have sump tube for outlet v band but inlet band for manifolds is not included £280
    5E407D6C-B61A-4B0D-A926-83E04AB224AD_zpsg2qlw1sr.
    790D1503-575F-491F-8FE4-7F81DB63EA21_zpspxhifgmx.
    26881301-594F-4864-B360-1E10E77159D6_zps7vmarl7d.
    16045F79-C6AD-465A-8731-E206509895CB_zpsjfyknikn.
    43E4108E-B951-45ED-AB7C-72B5D7C939FF_zpskcjl17wq.
    03D30F6D-753A-4F5A-9B72-E235C0E778DC_zpsai7h6mky.
    V band 2jz tubular manifold with v band outlet to suit precision or tial v band housing with 44mm v band outlet also as pictured very good con hard to find in this fitting worked perfect on my build and flows very well no cracks or repairs etc £450
    219AD240-FE82-4C71-B894-3B30E9119FEC_zpskoq6mhor.
    0F957AC3-A0A7-46C1-9679-8DE4331B328B_zpsi0y4i27b.
    9597E85B-0ACF-4168-BEC3-82435653209A_zpsgdzennq8.
    00188E3E-BF96-4A12-AD6B-5627B30030E7_zps9l1x9lbg.
    D088A42A-4384-4B3C-B758-0241054CC156_zpsarqsnydw.
    5C6B9E6F-88F7-4847-91BC-32655DF5B908_zpsarlzbahz.
  2. OW04NED
    OW04NED New Member
    west mids
    Samsonas bmw/universal short shift gear lever setup good con little use awesome bit of kit massively transforms the bmw gearbox gear change that we was running this year £300
    E8DF02DC-958B-48B0-9867-870AE95E36E6_zpsjdnamrgs.
    1413E48F-1CDD-4E34-92D7-488FE4A27F15_zpsmedvm5q8.
    7725052D-DD0A-4232-AA41-1ABDCB29CC5F_zpsjykdsit6.
    F523D486-CAB4-46E3-BE1D-4EF9A8503732_zpsla2dppad.
    Pmc 2jz to Bmw gearbox conversion kit only test fitted the adapter plate not actually run this one and same with the flywheel not actually been used flywheel has fitting kit still in bag bolts for adapter plate are included just not pictured. This is for the Bmw early 5 and 6 speed gearbox’s with the large input shaft £400
    8A1B9D21-5A7D-4EC9-A118-D22DD76B06EC_zpswdyggvrz.
    D13A726E-0AC2-431E-A057-36D0EE4A9CF4_zps1upcmywg.
    9995D8DF-0993-4871-8513-D9133E5E9C6F_zpsjmluphbf.
    9DE5A319-5902-4628-89E1-9EC5F7EB2734_zps7fevtvi5.
    BB16C07E-CA16-4B88-9A49-BB553622195E_zpssrmplaxm.
    7589FE34-0052-408B-AC47-769B8EA20EA7_zpsqcmmatew.
    3F39312C-9A4D-4FA7-A7E2-36B3D901D68D_zpsi384yja6.
    C4EF7925-61CD-4148-B0CC-5710EB4CF173_zpsoyjw3kjn.
    Sx 3 port adjustable fuel regular good working order fittings not included £100
    4B631F38-ACD6-474D-83EC-FD39FB92A110_zpsjaduaqf8.
    12DAF641-353E-4BA7-B24F-D9B2CC1BF35C_zpsxwlbklmn.
  3. OW04NED
    OW04NED New Member
    west mids
    1977 Celica custom drag rolling shell 8.50 spec cage in date/Hugh rear tubes arches custom 9inch ford end with diff /shafts/strange rear hubs/brakes/shocks/5link rear suspension set up/bladed rear sway bar/wildwood 4 pot front billet drag brake set up/bilstein inserts on oem dampers/modified steering rack position and mounts/engine mounts and subframe mounts/poly bushed tie rods/centre line front and rear drag wheels moroso 23x5.0/15 tyres/goodyear rear 30x12.5/15 tyres/fully glazed with Perspex rear and front side windows/complete with brake lines and line lock /dash /steering column and rack and removable steering wheel/chute removable mount £5000
    CFD940DD-FFCD-4CAD-BC56-BE73760F0596_zpsveiotywz.
    06E59F19-2AA1-4FE1-848F-1A8AF2B1DD61_zpslempvfb5.
    953158FF-9DA8-446B-997C-8B6400CCCBDF_zpsiawqtk3h.
    DE50635D-AE66-4F41-B1E7-8C04AE3B3697_zpsgjrn8w5u.
    BA0099C4-CF03-4E75-BE92-79BB726DEAE1_zpsqfruegq1.
    761F59D5-C246-4E4F-8B0B-9C46858AEA0F_zpshi0nywys.
    93CA0D69-AD74-4D52-BAE5-93231939FED3_zpsy7s7bv2r.
    8E4F1591-71A9-464B-BA60-A14A540124FC_zpsoj9bxzgx.
    5BCF971B-04D1-40B2-B893-D522F49DC55D_zpsszfbpdd5.
    25B3BF82-51C8-42B6-8E2D-0BA44BC667FC_zpscthdtrko.
    A337EBBB-C245-4700-8A7F-3B22645EA1AE_zps6oibifkt.
    24AB97F2-D299-40B1-85A5-C5F39A1FD071_zpsp3e5efxf.
    D5B2B9B2-754E-428C-833C-B719FD6ABC62_zpsoaybqd1t.
    505D72BE-8DDC-463C-813C-247FF9D1E256_zpsjy4ryevz.
    F5566CA6-43B6-4528-A467-9019DB2F0492_zpsf1wiwhba.
    B26D49BB-44CD-474D-B8FC-B87D67465B35_zpsczbvju2s.
    EB337D5F-CD9D-4555-B59E-845FD9D0B8A8_zpszbsegqha.
    EDAED745-9D44-42CF-968B-5EDA7B7C16F1_zpsktpnydph.
    D6AE3A9E-A49D-4F12-B267-EC30E00A7951_zpsy8t71smk.
    E2E1840E-42B1-4CFD-A5EB-EAEE3ABE4D08_zpsnfw5diwx.
    DE41476C-709E-4B97-91DE-32114CED01AB_zpshbtbt1bs.
  4. OW04NED
    OW04NED New Member
    west mids
    Precision twin scroll t4 turbo proven over 1000bhp...4inch v band ceramic coated exhaust housing / xs power twin waste gates/obx twin scroll manifold £1000
    F349CEF4-4522-40FD-9264-07F50097D288_zpshrhhjum1.
    BC1017A8-DBC8-4EB6-A8C1-5BD6A60ADD99_zpszrfavckk.
    C28F19D5-7F18-4672-BAB4-CA25B3D622C0_zpsl6pbesky.
    C9B1094A-DBCD-41DF-A6A3-641C77F27570_zpst50wzvdp.
    9331B609-1577-421A-8C4A-973B8729AD9C_zpsoy2p9dbx.
    8E5AB336-C164-4D18-8854-135239A219F7_zpslo2vxh19.
    3D903F2B-95B0-4D64-95B1-74A8B8F8806A_zpsdvlnotxh.
    D72846E3-E669-4303-8774-28708F1799F0_zpsr9dx65dw.
    5B93E0FE-5CD4-4622-AAD3-4E800181D3B0_zpsbwmlkqke.
    92707D5E-7F65-4856-9E10-C1845DAE8887_zpsesxhuavt.
    0F98E54B-60AA-46CF-99B1-0F3D39F19192_zpso6zsppcy.
    Custom huge front mounted high flow intercooler £400
    D6259321-8044-44A1-A586-7C658F0D31CF_zpssehvru9d.
    046FD421-F728-4027-9A9C-9A901D5452DD_zpsgdreozoz.
    38B594F2-B785-42C6-ACF1-8B0C6A85C537_zpsepgcu2cg.
    07740C03-A99C-4FBE-B024-07FB5C4305A8_zps8jule2nu.
    90D5B956-CE83-4976-ABB8-8C9F1F80CFED_zps1jkswc8q.
  5. OW04NED
    OW04NED New Member
    west mids
    cast high volume inlet fully welded on to oem smoothed runners so no joins to worry about worked very well around 650bhp with no issues with high flow top feed fuel rail with welded on -10 feed and -6 return fitting included has been ran with bmw dbw throttle so throttle and cable mount may need to be altered £180 (DIPSTICK NOT INCLUDED)
    6A96AAFF-0898-4857-9048-5277DE0F8A4F_zpsmaeeq2fc.
    B6F1FDD1-29F7-4FB4-9384-D1DC20D11996_zpssjdsownw.
    92B3C2D7-000E-4403-A2E8-3EE1961ACFBE_zpss5tidsem.
    378BD60F-2B55-4A35-9C91-85B553E9587F_zps7ydgct9m.
    DBC3E68A-E22D-4285-938E-19739E737482_zpsh0pk1o4v.
    03FE5897-B536-4D2B-9261-86CA83D421FC_zpszcckhzch.
    13182861-D04B-497F-9FB4-414A0450E65F_zps6esb7yox.
    80551158-AD97-4C98-AF08-2CC1F6CFA3A6_zpsad9iuoaj.
    Custom inlet with obx high flow fuel rail/q45 throttle body has been drilled for nos ports but we can weld up if not needed £350
    BAE1A005-68DF-4A74-B6D3-E10DAD0F0130_zpswcksavtj.
    4E69250F-F700-4C84-9394-16E0A890C304_zpslq7o7oa4.
    DBD533B3-9E3C-4CB3-A59B-09C0CA016B7D_zpsw3hs3wna.
    7AA4F808-D893-473A-BB41-5E4A78577F3C_zpsdohdmm9n.
    86DEB6A9-5595-4D79-9985-BF9E0D00501D_zpsvqfwx4di.
    uprated ls individual coilpack set with ht leads and bracket £100
    72046949-4EC7-4D2F-ADA6-A5DC53BB16EA_zpsgyuocbut.
    Aeromotive 3 port fuel regulator £150
    F10582F1-1AAA-4760-9B14-8536606EECEF_zpsjvwutvuk.
    05468D38-96A0-4442-B2F7-C545361E5CEB_zpsobjiacxw.
    A12D8710-14D0-44F0-A6B4-381DA9921D3F_zpszxwgxdqt.
    3bar map sensors
    368E0FA7-CE62-4CBF-BB16-C9D8383E14D5_zpsr56gpluy.
    40108BE3-EAF4-4E09-9935-C7E04A0E4D08_zps3lbqdp04.
  6. OW04NED
    OW04NED New Member
    west mids
    B&m drag shifter £150
    1F21726A-79B8-4116-96B2-FB94B1BCDDD7_zpskor0crgj.
    347136D1-5813-4751-981F-3BADF2C0DCAC_zpstpeyqp2b.
    442B3C9E-83EC-457F-AD5A-0ABADAF223CF_zpsjpftdjv8.
    Direct port nitrous system with large bottle and heater twin billet bottle holder/solenoids/lines complete £600
    54808A4A-FE6A-4169-A44F-3C35F8DA088A_zpsuzhulnsa.
    82C4BD64-25B8-42F6-BE9E-7F3D71276BFA_zpsdbbpof3d.
    DACC9587-F555-4C8C-A7D3-C2A34C18A9B7_zpskdjsmfru.
    A5BE6931-043D-4DB6-9F4C-6F9D338A8BF4_zpsm79skbh1.
    A344F225-3076-4BB5-9AE5-0CFDE8ED6281_zpsi2njvivh.
    82E0CBB8-BAB5-4F82-A9C0-8041D1E8AEAD_zps7bjqllqs.
    Trans temp gauge/oil pressure gauge/volt gauge/big tacho/boost/nos press gauge £300
    D62EDF19-6025-4529-AE3A-D3D25CA9192B_zps4jmu1ard.
    AE5299A3-C3BF-418E-B375-E48154ACE61A_zpsmzlpuf9s.
    40D317D1-7D6F-41F3-BE12-4BD647BA6B37_zpshaxmovyn.
    F6D2D8E9-52CA-4A76-855F-028EA368BB3C_zpsny6i1vcd.
    7C5BB75F-0FDB-441E-9E3B-C8F03736027A_zpssuflftul.
    E14DDDEB-B4B2-4746-BEE7-72E2C781ECED_zpshdviucaw.
    2jz to syvecs s6gp custom engine wiring loom bit messy but did work 100% £500
    75F8B234-BF32-4B4C-AFB8-D76FBB43180B_zpslpkza3e3.
    Bosch wide bank lambda sensor £100
    apexi 3port boost control solenoid £40
    8E4A03C3-6C4F-49E3-820E-D82A7E63C4D4_zps6jvr1n8l.
    A1382202-AE7C-4451-9D29-527062DC3298_zps5ubdkyhe.
  7. OW04NED
    OW04NED New Member
    west mids
    Panel less wiring switch panel £100
    E6EFDEBD-3AC5-4A68-89FA-66149B215059_zpsivfy7k0v.
    703D4ED5-F668-41DD-B167-967F9F754BB2_zpsepycjhvg.
    Diess chute £280
    5559A2CA-0D23-481F-9F1C-10B0CB9785B1_zpsujwxcha6.
    CD8EC46F-A412-494C-9A26-AC21CECABDAC_zpsv1gu83kw.
    6D2DE1FD-50D4-4DDA-BDC4-0F713F96FC31_zpsklbtpkqj.
    F3B0945E-AAD6-4E3A-B617-6149D772DDB1_zpsnm1ntr74.
    AC5CF8B3-6C1E-4618-9C87-18E0291EA577_zpsndkzpsc1.
    6355449D-91D2-4313-892F-FCE8991C4A6B_zpsorn2wzzh.
    Harwood fuel cell £80
    E8E69AAE-902B-423D-9B21-ABF8F136AECE_zpsw8foh1wy.
    0E63BB6A-EFA2-44B9-B78D-C7C2D5BD661B_zps5korqgll.
    5515AEC4-221F-4A80-824C-C691C50E0360_zps7vp8cvet.
    Magnaflow fuel pump pro tuner series mp44701 2000bhp+ flow £400
    33C87FC7-0548-47E4-A4EE-C51CF94DB647_zpso3k4bkhs.
    5FD1AFBA-E127-4709-AB61-BABDAFF2C160_zpssx4rfw3n.
    3E9DB1D2-A65B-4504-A563-B2F170D9C7BE_zpsun3apocq.
  8. OW04NED
    OW04NED New Member
    west mids
    Rear custom rad set up with craig davis water flow kit large high flow kenlow fan set up braided feed hoses and aero fittings /over flow tank etc £500
    4BCFA1D9-E1BD-4663-8C94-C5BE52B2A1AF_zpsmvomj1me.
    3E6828C0-103A-4AD2-B569-0E77C9EB0FC4_zps4owzxjj1.
    F6D402C4-366F-478F-9268-DFB7077CFB75_zps5ufrfngy.
    A7224151-1499-43CB-8D51-9A1534C54A1F_zpsgjjsdjtx.
    941C14B6-5D30-4D00-902F-1039BF3042A0_zps7dmz0etq.
    BEE873FF-BDE3-4863-86E2-E546DDE87FF5_zpsign4eokm.
    1885A953-6A67-4002-B02A-7A68774B8194_zpsb3b6ollw.
    6D56B884-C4DE-4A62-9AF6-F852A624E34E_zps3njpsyuz.
    994DA10B-DDA9-4FAB-B90C-F3A424A2B9EE_zpslaksbz29.
    japan racing enkei rep wheels 18x10.5j rears et15 & 18x9j et35 front very little use no curbing or marks do have enkei stickers added hard to tell the from genuine ones nice and light in 5x114pcd fitting rears have some 285/35/18 r888 tyres these are on there limits might get a track day out them thou etc £500
    8815CA5C-0013-4066-9739-0D5F79B480BD_zpsg6qdawju.
    D6B43593-8C3C-4740-82E8-E779242F2D37_zpsfqsg14ij.
    0F5B44B3-D004-4187-BEBB-B5CA71A04F4B_zpsftdehtiw.
    AF91F825-857D-4399-868D-1A95BB81CDAE_zpsaxjffa2w.
    C0951571-FDA7-452A-A128-7536E2F92246_zps2pfmhufa.
    6264F414-1C5F-403F-AB10-C8BC0DA9ED60_zps0kbhqvr1.
    99364653-5718-4652-84BC-E00B38FC9C32_zpsprcniwnn.
    2AFEF34F-DC1D-47FA-BD95-EAA784BBB840_zpsgq5xznta.
    6B8A3E7F-91AE-4EB4-AB74-A3506AC78814_zpsbyspqkwp.
    CA41B627-1ABE-4629-85BA-EE110885D901_zpsq7qezvka.
  9. dano
    dano Member
    carlow,eire
    Shame to see it be broke! Some stuff on that little celica! What size is the fuel cell?
  10. OW04NED
    OW04NED New Member
    west mids
    Fuel cell around 20litre but would use to check to 100% confirm
https://www.googletagmanager.com/gtm.js?id='+i+dl;f.parentNode.insertBefore(j,f); })(window,document,'script','dataLayer','GTM-BR4Q');
