500bhp diesel merc project
Thread in 'Project Cars and Builds Threads' started by mantahead, Feb 9, 2013.
  1. mantahead
    mantahead Member
    n-ireland
    hi,
    after experimenting last year with the c250td drift car, i decided to spend a bit more time and build a proper one this time. this time i will use a cleaner w202 shell and the 6 cylinder 0m606 from the e300td. this time i will use a m112 eaton supercharger and a hx52 or hx55 turbo, the last effort with the 5 cylinder made 385bhp,(on red diesel) with a standard exhaust manifold that was modified, this was restrictive.
    Here is some pics of my progress.
    after a wee look around the yard to see what back end i was going to use, work started.
    got some hks supra front coilovers with bottom bush,
    lets sort them out
  2. mantahead
    mantahead Member
    n-ireland
    not much room for mr eaton and pipework
    dont think it looks right up top
    stripped out inside
  3. R32 GTR
    R32 GTR Active Member
    Hillingdon, Middlesex
  4. mantahead
    mantahead Member
    n-ireland
    i think the eaton is going to have to go here.
  5. bennett442
    bennett442 Member
    suffolk
    proper bad ass
  6. Ruishy1
    Ruishy1 Active Member
    East Ayrshire
    nice, good to see something new instead of the usual R/S bodies and beemers
  7. mantahead
    mantahead Member
    n-ireland
  8. MercTurbo
    MercTurbo Member
    awesome project
  9. Zell
    Zell Member
    Lublin, Poland
    IIRC D-Mac had a steering quickener on the Saturn Sky he drove in FD USA. He praised it on one of the videos while talking about the car.
  10. harry.
    harry. Member
    kent
    cool project man .
  11. bogs
    bogs New Member
    Medway/Kent
    wow wow wow
  12. mantahead
    mantahead Member
    n-ireland
    cheers guys.
  13. Pizzodrift
    Pizzodrift Member
    Italy Reggio Emilia
    Another black smoke, cool ;)
  14. mantahead
    mantahead Member
    n-ireland
    hi,
    here is a video of the first car i used for testing purposes, it run standard 5 cylinder engine, 3.3bar boost. 385bhp/400ft lb.
    and also at the track
    #14 mantahead, Feb 20, 2013
  15. little_ant
    little_ant Member
    what have you done to run 3.3 bar of boost?
  16. bmurf
    bmurf Member
    newry NI
    seen the start of this project a few weeks ago when i was up in the yard. Your not wise at all lol. But good luck with it. Looks like a fair bit of work
  17. n1tr0_9
    n1tr0_9 Member
    Cranbrook, Kent
    Fantastic. This is like Scrapheap Challenge does drift cars!
  18. mantahead
    mantahead Member
    n-ireland
    the holset likes the boost, lol.
    in a diesel like this, more diesel=more boost, because i don't run a wastegate.
    if i fitted this turbo with standard injector pump i would only see just over 1 bar boost.
    engine is standard,
  19. Gazelle
    Gazelle Well-Known Member
    Essex
    What diesel pump and injectors are you running? I pressume the injetors are std??
  20. mantahead
    mantahead Member
    n-ireland
    yep, standard injectors, Dieselmeken pump. (oldskool pump with no electronics)
