It seems they're not compatible with tein tension rods as they do not have removable bolts where they fix onto the adjustable arm I've read the description in the shop again and to be fair I read it as "You need adustable tension rods" and not "You need our adjustable tension rods" As it actually says So, From the pictures it's hard to tell if your orange tension rods will fit - I assume they will, or do I need the ultimate carbon ones? Cheers
yeah I tried that for about 3 hours yesterday evening Ordering the orange ones the noo EDIT: Nil stock Carbon ones it is then
Doh forgot about the orange ones! Carbon ones are a touch thicker, they're a tight squeeze in the lower arm bracket but they do go. Removable bolts etc so, job done!
I've tried believe me... I might try again but if they come out now I'll have bought the new ones for nothing - so best leave them in!
