Here is a 944 I picked up not long ago, only used it the once, but I need the space back really. So its a 1985 2.5 Lux, no MOT or Tax, I do have a log book for it. It comes with bucket seat, Hydro, Welder, chopped front hubs, extended bottom arms. Someone (not me) has lowered it (this is a huge job at the rear), fitted new uprated springs and dampers, new brake lines throughout and supposedly rolling roaded and re-mapped (also not confirmed, but it does pull well), also suspect it has an uprated turbo clutch. Its a non sunroof shell (pretty rare to find) and has a manual steering rack (also not very common). It has also had the interior fully stripped out (I mean fully, no dash, heater not even switches for things like the wipers) It will come with a set of 15" cookie cutters fitted (as pictured in the static shots). I have loads of options available to change the spec to go back to std, or things like wheels seats etc that could go with for extra. Bad bits, well it wont go through an MOT without a load of work, things like headlights, switches etc to make them work, would also need some welding, although a lot has been done the sills are not great however not beyond saving. Car is near Wakefield in Yorkshire, £700
I said to myself as I was reading it - if thats less than a grand I'm buying it! Mind you, that was before I remembered how little money I actually have, lol, but the fact still remains thats a fucking bargain
Umm, the std 2.5 is about 170 ish, so power is not that different to a std E36 325. It also weighs a chunk less than a E36 too
