Ae86: Fitting A Turbo?
Thread in 'Technical Questions' started by MR.T, Jul 30, 2009.
  1. MR.T
    MR.T DRIFT RETARDED
    LOCKDOWN CITY, ESSEX
    i have a ae86 with a ae92 engine and want to know how i can fit a turbo to it or if i can use the supercharger set up from the 4agze?
    i know there are turbo kits knocking about but i dont have 2k to spend on one!
    i have seen turbo conversion manifolds for sale with t25 flanges
  2. SaqsAE86
    SaqsAE86 Active Member
    Slough
  3. EireBaz
    EireBaz Member
    Co. Cork, Eire
  4. retro-ed
    retro-ed Flicks 'n' Kicks
    Hinckley
    Nooo.. that car was badass N/A... easly enough power for pretty much anything and faultlesly reliable!
    Tony N on here has turboed his quite cheaply with good results.. But he is mega switch on with ecus and mapping. Its around 180 brake at 0.5 bar
  5. MR.T
    MR.T DRIFT RETARDED
    i'm not sure if i'd get many powers from adding cams and maybe itb's? do i need a 4agze engine to run a turbo and can i use the supercharger from the 4agze on my 92 block?
    i need powers but on a budget
  6. Paz
    Paz -NIGHTSPIRIT FAMILY- UK Drift Since 2001
    Stoke-On-Trent
    Just put more air in the rear tyres? Cheaper.
  7. MR.T
    MR.T DRIFT RETARDED
    i got 55psi, i just want a bit more power. i wouldn't mind about 180bhp tho ;-)
  8. Irishtwincam
    Irishtwincam Tá me sasta :D
    Cambs
    HKS turbo and exhaust manifold with downpipe.
    10042009992.
    Fab piping, IC and blow off mount.
    Pick your engine management, or buy a GZE ECU and sensors ready to rock from Leekun :D
    or
    HKS bolt on supercharger with bypass etc built in.
    No intercooler :( but its cheap easy to bolt on etc :D
    160420091420.
    160420091418.
    Again, Engine management of choice or GZE harness :D
    The factory 5th injector kit on a big port netted 160hp and similar torque here in Ireland.
    #8 Irishtwincam, Jul 30, 2009
  9. Irishtwincam
    Cambs
    If your going to do a full 4AGZE install, keep it tidy!
    20072009346.
    15072009289.
    20072009347.
  10. yogi bear
    yogi bear Active Member
    soufend innit
    or you could grow bigger balls and use momentum jay. commitment is your friend here son!
  11. Tony N
    Tony N Member
    Coventry
  12. Irishtwincam
    Cambs
    True that!
    Stock bluetop powers can get my 86, my brother and I sideways flat out in second and keep it like that.
    Right foot flat!:thumbs:
    Left foot kind of like >> :smash:
  13. Irietuning
    Irietuning Member
    Bedford
    Ive got a full ae101 gze loom, ecu and some sensors if required...
    Im not sure what boost you can run on it standard though if you run the tubo instead of SC
  14. Irishtwincam
    Cambs
    Stock GZE will fuel cut just before or at 14psi.
    MAP sensor cant go higher.
  15. Lead_foot
    Lead_foot DWYB ConekillR
    Chesham, bucks
    Easier to swap in a SR20
  16. Tony N
    Tony N Member
    Coventry
    No way dude, if you use a Power FC turbo charging a 4AG is pretty easy.
  17. Struggle
    Struggle Active Member
    custon manifold???
    easyest way if you want to do a cheap DIY conversion.
