{} {} {} {} {} {} {} {} {} This is it! Just finnished the mammoth task of rebuilding this JDM icon. Everything has been redone. The car has been taken apart to the last bolt and put together again with new or refurbished parts. Original Danish car. Original White and Black interior. Short run down of the car. Chassis: Extensive rust repair. Undercoated, all new Poly bushings everywhere, all new bearings everywhere, all new bolts everywhere. New brakes, calipers, discs, braided brake Lines and new hardlines everywhere, both brakes and fuel etc. New fuel tank, all painted to match in Black and TRD Grey. New stainless exhaust. All new suspension parts. Bc Racing coilover rear. Short stroke convertion coilovers front complete with gazz springs and KYB dampers and all new wheel bearings. Adjustable pillow mounts. All new steering setup/arms etc. New lenghtend LCA’s. New custom spacers made to spec to fit wheels and tyres and “Bride” tow straps. Engine/drivetrain: Complete rebuild engine with honed and skimmed block and head. New bearings, oilpump, new bigger Oil cooler with AN fittings and Lines. New Aluminum radiator, completely new engine setup with COP and crank trigger ignition and new Injectors. New fuellab FPR and fuelpump. New programmable ECU and wiring loom complete with Innovate LC-2 wideband lambda and controller. New gaskets, mounts, HKS aircleaner. New Black silicone hoses. Exedy stage 2 clutch and pressureplate. New realease bearing. Rebuild complete rear axle and LSD diff with all new bearings, seals and thrust washer. ALL new quality brand and spec. fluids. Exterior: Freshly painted panda color scheme. CBY overfenders fitment is on point! Fitted with countersunk washers, stainless bolts and threaded rivits. Trd spoiler, again, fitment is flawless. Corolla sprinter/levin decals. JDM Whiteline rear lights and center. Wheels/tyres: New 15x8.5 with new Toyo r888 195/50-15 front and 205/50-15 rear. And red lugnuts. Interior: Stock. Original Black/Grey. This is the only place that hasen’t been redone. Just fitted, and needs a once over if to be Perfect. Trunk popper fitted due to having the TRD spoiler fitted. Cd player. chassis has done 200000km. Odometer reset to 0 km as everything is new/rebuild… Extras. Original owners manuel that came with the car. Vintage Jdm/tein keyring. This is NOT for the purists out there…. This is modified and made a hell of alot more fun than Stock. Also welded… modified… you get the gist. These things will only go one Way pricewise… and there is only going to be fewer to come by… nuff Said. price 35000€ Dropped to 31000€ located in Denmark. No swaps
