Altezza 3sge beams + greddy turbo kit 0.6 bar | should I change the ECU?
Thread in 'Technical Questions' started by ccrroocc, May 31, 2018.
  1. ccrroocc
    ccrroocc New Member
    Hey everyone! Just installed the greddy turbo kit on my 3sge beams altezza. In the beginning it was just around 0.3 bar.. everything was fine. Recently I've lowered the compression and boosted to around 0.5, 0.6 bar..
    Here's the thing.. I have stock fuel pump, and stock ECU. While accellerating, whenever I press the throttle gently, and increase the throttle as it accelerates, it does pretty well.. but whenever I'm going full throttle, it doesn't.. I can see the turbo going up to like 0.5 bar, but it doesn't accelerate normally whenever I fully press the throttle..
    What could be the problem? Is it just the fuel pump, or I should buy another 500$ remapped ecu as well?
    Thanks in advance!
    20180322_183104.
  2. matthew_l
    matthew_l Member
  3. r3k1355
    r3k1355 Well-Known Member
    You should do both really.
  4. BenRice
    BenRice Well-Known Member
    Are you trying to fix it cheaply, or properly?
    Cheaply: adjustable FPR and wind 5psi more into the base fuel pressure
    Cheapish: Walbro 255, SAFC and add more fuel yourself
    Average: Walbro 255, SAFC set on a dyno
    Slightly more exy: Walbro 255, remapped ECU
    Properly: Walbro 255, bigger injectors, remapped ECU
  5. jabran200
    jabran200 Member
    I would start by getting an ecu as you need proper control of fuel and ignition at the very least.
