An MX5 with a plot twist...
Thread in 'Project Cars and Builds Threads' started by georgepoling, Jun 27, 2015.
  1. georgepoling
    georgepoling Member
    Southampton
    Went with the b235r in the end! the manifold design just changes, the ones i have is an equal length cast one, and is suitable for the td04 or any uprated model. as its cast and oem, it wont crack and will happily do the job unline some other ebay stainless items!
  2. Aidan_G
    Aidan_G Member
    is it the same as the saab 9000 manifold? i though the b2x5 series wasnt very reliable after 300hp? what was the reason behind for going with the b235r?
  3. georgepoling
    georgepoling Member
    Southampton
    No its different, areo only i believe. No its super reliable. same block as the 2.0L but just different crank and pistions ect. More torque and power to be had, only reason people use the 204 is the rev better, but we have removed the balancer shafts and fitted a lot of parts to make it rev super fast!
  4. Andy P
    Andy P Member
    Hedge End
    Needs more pics! :D
    Or a visit!
  5. georgepoling
    georgepoling Member
    Southampton
    Currently in sevenoaks working and living but will be back down hedge end way fairly soon. need to finish the little bits off, air filter pipework has arrived and ps lines are on order. then just get the 3" exhaust made and ill be back, and ill come visit for sure!
  6. georgepoling
    georgepoling Member
    Southampton
    SO we are finally finished (well there's always going to be little bits to do!)
    Its running 5 psi for the moment while its run in, but its scary already! Power steering done, 3" exhaust done, got some slimline fans to attach soon as well. As requested, pics and vids! (the cam cover needs polishing and some of the wires arent tidyed up yet apologies!)
    https://www.youtube.com/watch?v=UPByRBgrCus&feature=youtu.be - it wasnt cold, just taskes a while for water to burn off! ;)
    [​IMG]WP_20160403_09_50_13_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160403_09_48_24_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160403_09_48_10_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160403_09_47_52_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160403_09_47_39_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160403_09_47_15_Pro by gpizzle__, on Flickr
    #66 georgepoling, Apr 3, 2016
  7. Blake7
    Blake7 Member
    Awesome project buddy!! Well done!
  8. bcartmilldrift
    Can i sleep with it? dam man that thing is insane well done!!!!
  9. georgepoling
    georgepoling Member
    Southampton
    so its done around 300 miles in the last week, up and down the motorway and for some fast little drives. its going great, solved a few little leaks shes now going great. pulls hard on 5 psi so will run it in some more than get some mapping booked (y)
  10. Andy P
    Andy P Member
    Hedge End
    Excellent mate!
  11. Aidan_G
    Aidan_G Member
    cant wait to see this skid! how much power do you think you'll have after mapping?
  12. georgepoling
    georgepoling Member
    Southampton
    we are hoping for around the 300 whp mark. its running 5 psi atm and having pulled aganist and dyno'd turbo mx5 at 230 whp it was faster, so more boost and a map should see for a nice figure!
  13. Aidan_G
    Aidan_G Member
    Have any upcoming drift days booked? Bet this goes like shit off a shovel. Also is the b235r different from the b235e and b235L in terms of internals or are they all the same with minor changes like ecu, tpc, low boost and high boost? Cheers:thumbs:
  14. georgepoling
    georgepoling Member
    Southampton
    yeah they are basically the same just different turbos and ecus and some other bits. Nothing uey, but ill be up at pod or Rockingham to shake it down fairly soon once its been run in and mapped
  15. Milton
    Milton Member
    when is this going to be at pod next, need to see this thing in person !
  16. georgepoling
    georgepoling Member
    Southampton
    hopefully soon, depends when i can get work off next!
  17. georgepoling
    georgepoling Member
    Southampton
    Been out and about, down in maidstone the other day, all going sweet so far! running a touch more boost (10 psi) with 25 psi in the rears and it squats hard. buckets of power, will spin the wheels in third easy :rolleyes:
    [​IMG]WP_20160410_23_13_05_Pro by gpizzle__, on Flickr
  18. georgepoling
    georgepoling Member
    Southampton
    Time for a bit of a thread update as much has happened.
    [​IMG]6tag_160416-132536 by gpizzle__, on Flickr
    Been driving the car on the road for the last few weeks, everythign going really well, making about 270 whp at 14 psi. The prop that was made as a job on the cheap just temporary finally gave up the ghost pulling hard down the motorway :no:
    [​IMG]wp_ss_20160418_0001 by gpizzle__, on Flickr
    [​IMG]6tag_210416-075045 by gpizzle__, on Flickr
    New prop made with extra thick tubing so will easily handle whatever we throw at it. When the old prop snapped we decided it would be a good idea to do check everything over so removed the whole drivetrain to check everything. Installed the upgraded diff which is only 1000 miles old, checked the clutch over to make sure it was working properly and the engine to ensure everything was working fine with the dry sump.
    Found the diff has cracked one of its welds, so took the chance to fit a better ratio (4.1) diff, get it full with weld with 4mm plate for a little extra strength, and also added some 4mm plate to each side of the diff to make sure it doesnt crack like many others that have had the issue. I dont think it'll be cracking in a hurry! :rolleyes:
    [​IMG]IMG_8484 by gpizzle__, on Flickr
    [​IMG]V__A437 by gpizzle__, on Flickr
    [​IMG]WP_20160429_14_19_51_Pro by gpizzle__, on Flickr
    [​IMG]WP_20160429_15_40_14_Pro by gpizzle__, on Flickr
    Shes now back all sorted, sweet as! Im goign to the Mazda Hq in dartford on saturday which should be a laugh :cool:
    Sorted out the horns and some paint to tidy it up, looks ready for battle now!
    [​IMG]6tag_160516-102426 by gpizzle__, on Flickr
  19. Blackett
    Blackett No Comment
    @ Santa Pod
    Great project, I'm toying with the idea of a Saab powered Mk3 MX5. :)
  20. georgepoling
    georgepoling Member
    Southampton
