apexi avcr fitting help plz
Thread in 'Technical Questions' started by chri5, Mar 7, 2011.
  1. chri5
    chri5 Active Member
    croydon on sea
    i have an Apexi AVCR fitted to my s14 and i am a bit confused???
    the part circled blue is the apexi solenoid.
    when you follow the pipe it is linked into the hot side of the intercooler pipe but also branches into 2 and that goes to the inlet manifold and recirc valve.
    there is also another t piece but this just goes to atmosphere.
    in the pink circle appears to be another (maybe oe) boost solenoid which links into the cold side of the intercooler pipe work.
    cars running at 1bar boost but doesn't seem to have the turbo kick if that makes sense???
    can anybody tell me the correct way to fit this as i am guessing that its not right???
    thanx in advance
    chris
  2. al.
    al. actually dom joly
    Worthing, near Brighton
    nipple on the hotpipe/compressor housing > boost solenoid NO port
    boost solenoid COM port > wastegate actuator
    boost solenoid NC port is left open
    then connect the port on the inlet manifold to the recirc directly
  3. "Clarkey"
    "Clarkey" "Full Attack!"
    Croydon, South London
    as i said the other day, the saucer thingy plugs to the vacum, the main solonoid connects to the cold pipe and the actuator. im not really sure why theres the connection on the hot pipe??
    does anyone know different?
  4. chri5
    chri5 Active Member
    croydon on sea
    So mines connected totally wrong then???
    Which explains no boost 'kick'
