apexi power fc + commander
Thread in 'Technical Questions' started by copeyhagen, Aug 4, 2010.
  1. Pure Performance UK
    Pure Performance UK Active Member
    keep it off boost and you'll be absolutely fine...
  2. gstuning
    gstuning Member
    Oxford
    Some? It will compensate for any.
    Also
    Assumption #1. The ecu has been tuned for the other car safely and proved reliable.
    Assumption #2. Same MAF, Same injectors and fuel pressure on both engines.
    Results : Car will drive great.
  3. Pure Performance UK
    One thing though....it uses a MAP sensor.
    The ecu came off a car with a decat meaning the turbos will spool a lot quicker and may run at a higher pressure. This will run the map rich on your car as there isn't the air there was on the other car's setup.
    Whether or not the Apexi has the same ability to adjust as the OEM ECU I don't know...I imagine it does but I can't be sure.
    OP-keep the car off boost and you will fine.
    #23 Pure Performance UK, Aug 5, 2010
  4. copeyhagen
    copeyhagen Member
    dublin
    its in with robbie @ trackdayperformance (www.tdp..ie) for a mapping next thursday. he had mapped it originally for the other lad and is probably the no1 mapper in the republic of ireland.
    she wont be gettin driven till then but when shes on her way down will be off boost.(will be tough though :p)
    will have to get under it tonight and check to see if the cat is in, its a brand new exhuast system put in before it left japland.
    cheers for replies lads
    rob
  5. xlogic
    xlogic Member
    Can’t he just reset to the base map on the paper fc?
  6. r3k1355
    r3k1355 Well-Known Member
    The thread is nearly a decade old, what the fuck are you playing at?
    • Funny Funny x 1
  7. tomsheen
    tomsheen Active Member
    Ireland
    I wish Bizzle was still hear you say something witty
