S14 boss 1uz v8 bdc spec Life has changed so this is priced for a quick sale it is bdc spec so ready for competition or daily it like I used to haha Exterior S14 with a boss kit fitted Custom headlights and loom 50mm over fenders Rocket bunny rear bumper May have a brand new windscreen if I get time Rocket bunny ducktail Roof spoiler Extreme offsets with brand new 225/45/17 not seen a single mile All welding has been cut out and welded Rear arches cut higher up and re welded Tubed front end painted orange Interior Bdc spec full bolt/weld in roll cage with door bars still have the bdc sticker on FIA approved brand new mirco rs1 orange and black FIA approved brand new driftworks harness Standard passenger seat Aftermarket steering wheel and boss kit 0.625 hydro all plumbed in with extra long handle Custom switch panel with kill switch and fire extinguisher Full fia approved plumbed in fire extinguisher with pulls cords in and out of the car Battery relocated behind passenger seat Fuse box relocated to passenger airbag cover Speedo works Rev counter doesn’t probably not wired up May put new carpet in Engine Front end tubed and bay painted orange Aluminium radiator 1uz v8 full manual conversion Custom wiring loom Separate custom engine harness with custom fuse box and fault code Brand new rotors, dizzys, coil packs, ht leads, spark plugs, all new fluids, new air filter Custom intake pipe Custom mounts Custom gearbox mount Custom prop Custom exhaust from headers back ABS deleted properly as hydro is plumbed in Brand new gearbox oil Regularly serviced Underneath 25mm extended lower arms Extended inner tie rods Modified hubs Skyline front brake conversion Brand new rear brake pads Brand new rear drop links Solid subframe bushes Welded diff Adjustable rear arms Probably forgotten a few things, problems they all have them, cracked windscreen May get a new one depending if I find the time, no mot as was using it as a drift car more then a daily by the end of it, I’ve priced it low to allow for mot can’t see it needed much if anything but life has changed so no longer needed 8.5k Ono located in Plymouth If genuinely interested text me on 07933049143 will WhatsApp more pictures. {} {} {} {} {} {} {} {}
Yeah mot expired from my guessing all it needs is a windscreen not too sure of anything else if genuinely interested text me
