BEE*R Rev Limiter help?
Thread in 'Technical Questions' started by indicacorp, Jul 7, 2020.
  1. indicacorp
    indicacorp New Member
    So I have this shitbox project car... It's a 2008 Ford KA mk1. Literally just a banger for shits and giggles.
    I have also semi-installed a BEE*R Power Builder type B.
    How is it semi installed?
    Grey wire is cut because its a 4 cylinder.
    The red wire is hooked in to the OBD-II +12v wire. (power)
    The black wire is hooked into ground. (ground)
    The white wire is not currently used. (switch for 2 step)
    The green wire is hooked into the magnetic pickup positive (0 degrees crank sensor | IGN) << Cant remember
    The yellow wire is not hooked onto anything (This should be for RPM) << Which way
    Now the limiter IS a fake BUT its probably the best fake so far.
    With the current configuration, it limits at what it seems like maximum gain at 3500rpm and makes some good pops like a machine gun. Its all good fun haha.
    But the dials are do nothing, and the red light is very dim.
    To currently toggle 2-step I have a switch going along the green wire.
    v3iSPC8.
    Above is the fake asf print circuit of the BEE*R. According to the traces the dials (variable resistors) should definitely do something so im not sure on what to do next.
    Another trouble I have is the car has 2 IGN wires. One wire fires 2 cylinders, the other fires the other 2.
    I literally have no idea on what to do next and it is very frusterating.
    THE LIMITER WAS GIVEN TO ME BY A FRIEND, FROM WHICH IT APPARENTLY WORKED FINE IN HIS MX5 MK1.
    Any help would be much appreciated, even for the shitbox I own.
    (But hey, who has ever seen a 2 step Ford KA?)
    #1 indicacorp, Jul 7, 2020
