Beginner BMW
Thread in 'Project Cars and Builds Threads' started by R32 GTR, Nov 1, 2010.
  1. Mike@TDSW
    Mike@TDSW Active Member
    It's sitting nicely now and the sounds are good.
    There's another one local to me that's just been finished too, so much want for one of my own.
  2. R32 GTR
    R32 GTR Active Member
    Mike do it, with your driving skills it would be a weapon. I'm hoping there are videos from Santa Pod if not then i'll get some from the 20th
    V
  3. Mike@TDSW
    As soon as one the manifold makers decide to mass market an off the shelf solution I'm on it.
    All the ones done over here either have shocking manifolds or 1-2ks worth of fab work in them.
    Tbf I'm quite tempted just to pick up a left hooker and save some headaches. Don't mind skidding lhd.
  4. R32 GTR
    Mike speak to Elite Developments they were looking at getting some cast iron ones made up. Alternatively you can have my Gunni monstrosity which he claims will work
  5. dan_gsxr
    dan_gsxr Member
    would love to do a build like this!
    what headgasket did you use in the end? im going to build a 328 engine to go in one of my cars thats supercharged. i only plan on using 10-12psi so not alot and ive been told to just go for a mls headgasket but not sure on the thickness to bring the ratio down...
  6. R32 GTR
    I'm using a Cometic MLS Headgasket but i might change it for a decompression plate from Ferriday Engineering
  7. kam
    kam I've touched Chris Parry
    How come? And go back to stock gasket?
    Does it keep blowing rocker cover gaskets? Is there a breather problem?
    *I sound like the Gestapo :wack:
  8. R32 GTR
    Kam a few people including Greg have said that MLS isnt the best solution for a high compression engine. It does weep from the headgasket every now and then.
  9. kam
    What CR is it?
    I don't see the difference between a MLS and a decompression plate to be honest.
  10. thomas666
    thomas666 Member
    Mike, manifold ready from shelf won't be any cheaper than my custom made one, check full boost and full race ones, they big money and they don't do bmw's, trust me for me to make one for 1200/1400 is pretty cheap considering is build with same material full race manifolds are, and is one off. it really is worth spend money to have a good results.
  11. kam
    Yup, the production numbers for a £200 generic SR20DET manifold using half the material will be in the 100's.
    No chance with something like this.
  12. Stavros
    Stavros Active Member
    And they're junk that crack and break and warp after half an hour.
    My cheap eBay (but better quality than most I'd seen) Skyline one was bent like a banana after very little use, all 3 flanges, head, turbo, and wastegate, had to be re-faced. Didn't have it long enough to crack, but that was next no doubt lol.
  13. kam
    I was just reffering to what's needed to get costs down on something like that.
  14. R32 GTR
    There's no real simple way of getting costs down. the quality and thickness of the metal used combined with Thomas's fabrication work were the only costs. Neither of these can be cut back on. Plus each set up is different, i have a big lock kit so turbo placement was restricted.
  15. Kelvjy
    Kelvjy Member
    so it's m50b25 @ 10:1 CR? surely that is fine... What kind of turbo pressure are you running?
    I have an m30b34 (10:1) @ 1bar of boost with no issues (MLS & ARP head studs)
  16. R32 GTR
    1.2 bar pressure.
    As mentioned no major issues just i just want to make it bullet proof
  17. thomas666
    thomas666 Member
    for good 6 cylinder manifold stainless I spend around 300 pounds on material and this is with my discounts as well, good stuff cost money that's it, and if you think you can get a manifold from ebay new from 250 pounds witch do not even cover the costs of the good materials then you can't expect nothing good, is some time now that I dont build cars/engines with this crap, or good stuff or I make it or I'm not doing the job as is just asking for problems sooner or later.
  18. andeep
    andeep Member
    Get low comp pistons or machine the stock ones if theres enough material
  19. R32 GTR
    The car will be at Pod on Wed, Lydden on the 30th and Snetterton on the 8th. Lets see how she holds up
  20. Clive
    Clive Active Member
    Fair plays sir!
    Got any outside videos yet?
