Best way of removing overspray?
Thread in 'Technical Questions' started by sammysideways, Mar 9, 2011.
  1. sammysideways
    sammysideways Active Member
    ETWE S P Brown 3S Mess HMS York BFPO 430
    Been doing some painting the car even though i masked of the area ive got a patch that has some overspray/paint where i dont want it, whats the best way/product to remove this?
  2. richy d
    richy d Active Member
    birmingham
    im pretty sure t-cut should do it,not the polish,the proper cutting stuff.or g3 should do it.
  3. hansen
    hansen Member
    Melbourne, Australia
    try using a little bit of brake cleaner and a clean polishing cloth, or you can go and buy a CLAY BLOCK costs a bit more but they are pretty good, pretty much what they where designed for.
    i sprayed my car not long ago and had plenty of overspray on the windows and seals and the brake cleaner did the job :thumbs:
  4. GTS GAV
    GTS GAV Active Member
    The dirty south..!!
    Don't tcut, I have tried every way possible,
    The cleanest an quickest is clay barring
    grab yourself a mguires clay bar set from halfrauds, spray the detail spray all over the area work the clay bar in your hands so its soft and rub it round an round in circles spraying more detailer to keep it lubed, wipe dry bobs grannys dog
  5. GTS GAV
    The dirty south..!!
    Beaten to it lol
  6. hansen
    hansen Member
    bit more detailed than mine though dude haha!:rolleyes:
  7. rhys_e_boy
    rhys_e_boy Member
    paintthinners , simple , just clean area after :)
  8. Gavwan
    Gavwan Back to Black
    Essex
    Tcut uses chemicals to take back paint not 'bite' like G3. If it's on a painted panel use G3 compound out of them 2 options. I've never used clay barring so can't comment on that
  9. J_K_P
    J_K_P Active Member
    near Exeter
    Only use clay if you're going to polish/paint correct the whole car.
    Clay by it's nature has got sharp stuff in it which takes oxidisation and stuff sat on the paint off but leaves scratches behind. Not big scratches but scratches.
    A mate of mine just bought a 54 plate Mitsi Lancer and the paint was in a serious shit state all over.
    The guy had even got over spray on the doors and bonnet.
    The first picture is after claying but before compounding/polishing.
    This picture is after compound/polishing but before wax.
    Go to a decent car spares shop and get some Farecla G10. That'll do exactly what you want.
  10. m1tch
    m1tch Member
    replace offending oversprayed parts with carbon fibre? :D
  11. sammysideways
    So im looking for paint thinners or brake cleaner?
  12. Mitch
    Mitch In moderation
    South Wales
    After seeing the jobs you did on the 180 and PS13 engine bays, you really shouldn't be allowed anywhere near paint :D
  13. Mike@TDSW
    Mike@TDSW Active Member
    Somerset
    Lol no, did you read the replies? G3, g10 or clay bar. Don't use chemicals to take it off as it could damage the paint.
    Personally I'd use g3 and it will be fine unless it's a posh car then I would do all the stuff Jk posted.
  14. GTS GAV
    The dirty south..!!
    I like your thinking buddy
  15. Bon Bon
    Bon Bon It'll be fine
    Solihull
    Petrol and 100 grit sandpaper will get any unwanted overspray off a treat.
  16. Stavros
    Stavros Active Member
    Isle of bollocks
    Spray over it
  17. colum
    colum Member
    [​IMG]???
    seriously though, g3 will be fine
  18. pizza_boy
    pizza_boy Member
    Maidstone, Kent
    brake fluid :D
    worlds best paint stripper that stuff...works a treat on pretty much anything
  19. bodgeabit
    bodgeabit Member
    G3 or g6 and a mop dont touch it with thinners if the panel is painted in any other than 2k which i doubt you know,it will come off !
